IDENTIFICATION 1 1/2 SU https://www.ausmini.com/forums/viewtopic.php?f=2&t=54904 |
Author: | ALPINE MOKE [ Mon Jul 06, 2009 5:37 pm ] |
Post subject: | IDENTIFICATION 1 1/2 SU |
I have found a brand new 1 1/2 SU in my shed, can somebody help me identify it and what vehicle does it fit. The tag on the fuel bowel the alloy tag reads AUD660 , on the body is the following cast markings AM/PDC1. The body of the fuel bowl AUD2140 THANKS |
Author: | Morris 1100 [ Mon Jul 06, 2009 6:10 pm ] |
I just found a reference to an AUD660 on a Hilman Hunter. I will keep digging. ![]() |
Author: | Morris 1100 [ Mon Jul 06, 2009 6:40 pm ] |
Hillman Hunter 1975 1496cc - 1724cc - HS4C Interconnect = LHIC Needle = CUD1044 Needle Guide = AUD4288 Needle Screw = AUD4251 Piston Spring = AUC1167 Damper = CUD4103 Jet = AUD9814 Needle and Seat = WZX1100 Float = WZX1300 Throttle spindle = WZX1316 Throttle Disc = WZX1387 Piston spring AUC1167 = Yellow, Load at length 8oz - 2.750in. Needle AUD1044 = ABW That is all I can find. |
Author: | ALPINE MOKE [ Mon Jul 06, 2009 8:34 pm ] |
Post subject: | SU |
Well done morris 1100 |
Author: | Morris 1100 [ Mon Jul 06, 2009 8:41 pm ] |
Does the choke linkage look a bit funny? ![]() |
Author: | ALPINE MOKE [ Mon Jul 06, 2009 8:46 pm ] |
Yes a little different, I nearly put it on my 1275 moke today as my SU has seen better days |
Author: | Morris 1100 [ Mon Jul 06, 2009 8:48 pm ] |
In the book the HS4C has a different choke that throttle linkange setup. If it fits use it! ![]() |
Author: | gafmo [ Mon Jul 06, 2009 9:19 pm ] |
cool I i'v got two trie thies Number on Float Bowl H?L3BW-F6 A_3302H Fuel bowl is on the Clutch Side Bugger the other one doesn't have numbers but has the bowl on the Radiator side...but under the butterfly shaft "Opposite side" from the linkages it has 3 dots in a triangle and #2 |
Author: | simon k [ Mon Jul 06, 2009 9:22 pm ] |
gafmo wrote: cool I i'v got two trie thies
you did a what?? |
Author: | gafmo [ Mon Jul 06, 2009 9:24 pm ] |
ow crap...didn't look at what I typed again Should have read..."Cool I'v got two of these" |
Author: | MG Rocket [ Tue Jul 07, 2009 7:12 am ] |
Morris 1100 wrote: That is all I can find. Morris! How come you know so bloody much? |
Author: | Morris 1100 [ Tue Jul 07, 2009 6:06 pm ] |
MG Rocket wrote: Morris 1100 wrote: That is all I can find. Morris! How come you know so bloody much? Because I am farking good. ![]() Here is how I did it.... Step 1) I Googled "AUD660 SU" and the first result on the page was this site... http://www.oldengine.org/members/diesel/SUCarburettors/SUCarbMenu.htm Step 2) Read that page, scratch my head and start opening pages and came up with this one.... http://www.oldengine.org/members/diesel/SUCarburettors/SUButecParts4.htm Step 3) Find AUD660 on that page and it listed Hilman Hunter but no details. Step 4) Go to my trusty SU book.. ![]() Step 4a) Look up Hillman, dang no Hillman. ![]() Step 5) Copy everything from teh book into the above post. Step 6) Bask in glory. ![]() ![]() ![]() |
Author: | gafmo [ Tue Jul 07, 2009 8:00 pm ] |
Hay Morris what about Mine ![]() |
