Easy Mini improvements https://www.ausmini.com/forums/viewtopic.php?f=2&t=54998 |
Author: | Austin850 [ Thu Jul 09, 2009 11:44 pm ] |
Post subject: | Easy Mini improvements |
Just fitted a headlight relay and electronic ignition this evening. I know it's been said a million times on this forum, but jeez they make an improvement. I already had a good set of H4s but the relay really does make a noticeable difference. The ignition setup was an old 'Allison' brand optical setup with an external amplifier. Easy to fit and seems to have made the throttle more responsive and the idle much less erratic. Thanks to Syd (Tspeed Jem) and Scott for help with the fitting. Cheers, Simon |
Author: | superSeven [ Fri Jul 10, 2009 1:39 am ] |
I'm yet to do the electronic ignition conversion, but will when I get back to Aus, along with alternator conversion.. to add to the list of easy mini improvements.. retractable seat belts 2 x 8 blade fuse box thermo fan oh and steering column lowering bracket! |
Author: | Convertible Mini [ Fri Jul 10, 2009 6:56 am ] |
Post subject: | Electronic Mini stuff |
I supply many of these things and I also help people with How to's. This is my line of work and I am now specializing in special English car stuff. |
Author: | superSeven [ Fri Jul 10, 2009 7:43 am ] |
Post subject: | Re: Electronic Mini stuff |
Convertible Mini wrote: specializing in special English car stuff
Is that the technical terminology? ![]() |
Author: | Austin850 [ Fri Jul 10, 2009 10:12 am ] |
Convertible Mini wrote: I supply many of these things and I also help people with How to's. This is my line of work and I am now specializing in special English car stuff.
Yep sorry Tony. Was considering one of yours but one of my mates had this one not being used so thought I'd give it a go. |
Author: | sgc [ Fri Jul 10, 2009 10:20 am ] |
superSeven wrote: oh and steering column lowering bracket!
It's a simple thing, but this one is gold.. make the driving position muuuuuuch friendlier ![]() |
Author: | gafmo [ Fri Jul 10, 2009 9:00 pm ] |
sgc wrote: superSeven wrote: oh and steering column lowering bracket! It's a simple thing, but this one is gold.. make the driving position muuuuuuch friendlier ![]() when you do this please lossen you rack bolts 4 nuts ( 2 U Bolts that hold the rack) so it will move to adjust to the change in the position of the steering column |
Author: | leema [ Fri Jul 10, 2009 9:37 pm ] |
rover seats. or just got solid seats that dont sag to the floor make a much more solid feeling ride highly recommend |
Author: | jimmyinamini [ Fri Jul 10, 2009 9:42 pm ] |
gafmo wrote: sgc wrote: superSeven wrote: oh and steering column lowering bracket! It's a simple thing, but this one is gold.. make the driving position muuuuuuch friendlier ![]() when you do this please lossen you rack bolts 4 nuts ( 2 U Bolts that hold the rack) so it will move to adjust to the change in the position of the steering column thanx 4 that gafmo my car has steering drop bracket was on when i brought it now you have given me something to check |
Author: | gafmo [ Fri Jul 10, 2009 9:57 pm ] |
hate to think how long its been like that....trust me it stuffs your rack up quick smart. If you purchsed with the drop bracket already on I'd be in two minds weather to touch it. Its more to the point if your adding a steering bracket or replacing the rack. If it aint drockendon't touch it. but in the future you feel something not rite at least you have some where to start from |
Author: | jimmyinamini [ Fri Jul 10, 2009 10:11 pm ] |
ok thanx ill leave it alone then i probably done bout 1000 kms in the car seemes alright hope it is alright i guess time will tell |
Author: | Morris 1100 [ Sat Jul 11, 2009 6:32 pm ] |
Don't leave it alone. Check it. Undo the rack U-bolts and if the rack settles you may have saved your life. If the rack does not move it was all OK and you do up the nuts and it has only cost you a bit of time.. Check the clamp on the bottom of the column. The pinch bolt should be tight and the column should not move in and out on the pinion shaft. If it is moving you need to fix it right away. |
Author: | dove grey 64 [ Sun Jul 12, 2009 9:06 am ] |
"Don't leave it alone. Check it. Undo the rack U-bolts and if the rack settles you may have saved your life. If the rack does not move it was all OK and you do up the nuts and it has only cost you a bit of time.. Check the clamp on the bottom of the column. The pinch bolt should be tight and the column should not move in and out on the pinion shaft. If it is moving you need to fix it right away." ![]() ![]() anyway still drove it home, just had to turn the wheel about 8 times until some teeth grabed the splines, was quite hairy doing hook turns in the city with no steering. |
