Help identify 18 engines https://www.ausmini.com/forums/viewtopic.php?f=2&t=55060 |
Author: | Kennomini [ Sun Jul 12, 2009 1:00 pm ] |
Post subject: | Help identify 18 engines |
To cut a long story short I have 18 engines I want to identify. I want to know the cc, year, make and model that each engine may have been used in, some of these may also be moke engines. The confusing ones first; (1)Engine # V7I786 P (either a P or a 10) (2)Engine # 903/1J (or a U)H/U13Y9the last set is stamped upside down ![]() (3)Engine # 8Y/U/H21047 (4)Engine # 99H834AJ/H6765 (5)Engine # 99H834AJH011167 (6)Engine # 99H33AAJH(either a U or a 0)11655 (7)Engine # 99H905AJH000527 (8)Engine # 99H834AJ/H4869 (9)Engine # 99H119/H1082 (10)Engine # 99H860AJH003068 (11)Engine # 9YA/Ta/H7996 (12)Engine # 99H834AJH008690 (13)Engine # 10Y/Ta/H36977 (14)Engine # 10YF/U/H9041 (15)Engine # 10004672 (16)Engine # 100112389 (17)Engine # 1015/10875 (18)Engine # 10Y/Ta/H56233B So obviously their are some strange combinations (some are strange to me) and it is a lot of info I'm after but if you can help out identify any engine I'd really appreciate it. |
Author: | TheMiniMan [ Sun Jul 12, 2009 1:04 pm ] |
Post subject: | Re: Help identify 18 engines |
Kennomini wrote: To cut a long story short I have 18 engines I want to identify.
I want to know the cc, year, make and model that each engine may have been used in, some of these may also be moke engines. The confusing ones first; (1)Engine # V7I786 P (either a P or a 10) ---> probably Victorian Police stamped from being shaved at some point in it`s life (2)Engine # 903/1J (or a U)H/U13Y9the last set is stamped upside down ![]() (3)Engine # 8Y/U/H21047---> 850cc (4)Engine # 99H834AJ/H6765---> 998cc (5)Engine # 99H834AJH011167---> 998cc (6)Engine # 99H33AAJH(either a U or a 0)11655---> 998cc (7)Engine # 99H905AJH000527---> 998cc (8)Engine # 99H834AJ/H4869--->998cc (9)Engine # 99H119/H1082--->998cc (10)Engine # 99H860AJH003068---> 998cc (11)Engine # 9YA/Ta/H7996---> 998cc (12)Engine # 99H834AJH008690---> 998cc (13)Engine # 10Y/Ta/H36977---> 1098cc (14)Engine # 10YF/U/H9041--->1098cc (15)Engine # 10004672--->1098cc (16)Engine # 100112389--->1098cc (17)Engine # 1015/10875--->1098cc (18)Engine # 10Y/Ta/H56233B--->1098cc So obviously their are some strange combinations (some are strange to me) and it is a lot of info I'm after but if you can help out identify any engine I'd really appreciate it. |
Author: | sgc [ Sun Jul 12, 2009 1:08 pm ] |
Kennomini wrote: (1)Engine # V7I786 P (either a P or a 10) This one is a Victorian Police-issue number -- you'll have to rely on other identifying features of the engine to figure out what this is. Kennomini wrote: (17)Engine # 1015/10875
This is an 1100 out of a 71-73 Leyland Clubman or Van IIRC. |
Author: | simon k [ Sun Jul 12, 2009 1:08 pm ] |
year, make and model is a bit specific... you should be able to identify most of them via searching on here Kennomini wrote: (1)Engine # V7I786 P (either a P or a 10) Victorian police issue number, issued in 1986, could be anything
(2)Engine # 903/1J (or a U)H/U13Y9the last set is stamped upside down ![]() (3)Engine # 8Y/U/H21047 850 (4)Engine # 99H834AJ/H6765 late clubman 998 (5)Engine # 99H834AJH011167late clubman 998 (6)Engine # 99H33AAJH(either a U or a 0)11655late clubman 998 (7)Engine # 99H905AJH000527late clubman 998 (8)Engine # 99H834AJ/H4869late clubman 998 (9)Engine # 99H119/H1082late clubman 998 (10)Engine # 99H860AJH003068late clubman 998 (11)Engine # 9YA/Ta/H7996 mini deluxe 998 (12)Engine # 99H834AJH008690late clubman 998 (13)Engine # 10Y/Ta/H36977 mini K (14)Engine # 10YF/U/H9041 (15)Engine # 10004672 clubman 1100 (16)Engine # 100112389 clubman 1100 (17)Engine # 1015/10875 clubman 1100 (18)Engine # 10Y/Ta/H56233B mini K |
Author: | Kennomini [ Sun Jul 12, 2009 3:52 pm ] |
Thanks Simon that's the kind of info I'm after ![]() |
Author: | Morris 1100 [ Sun Jul 12, 2009 6:56 pm ] |
I can do better but it will cost you. ![]() |
Author: | Kennomini [ Sun Jul 12, 2009 7:35 pm ] |
Aww come on you know you want to shed some light on this... |
Author: | Morris 1100 [ Sun Jul 12, 2009 8:09 pm ] |
(1)Engine # V7I786 P (either a P or a 10) Victorian police issue number, issued in 1986, could be anything Yep (2)Engine # 903/1J (or a U)H/U13Y9the last set is stamped upside down ![]() (3)Engine # 8Y/U/H21047 850 Yep, later car with Australian motor, so 64/65. (4)Engine # 99H834AJ/H6765 late clubman 998 Leyland Mini / Mini S. ADR27A Air pump engine, late 76? (5)Engine # 99H834AJH011167 late clubman 998 Leyland Mini / Mini S. ADR27A Air pump engine, late 76? (6)Engine # 99H33AAJH(either a U or a 0)11655 late clubman 998 ADR27A Air pump engine, late 76? The A in the engine number should be a 4 (7)Engine # 99H905AJH000527 late clubman 998 I have nothing for the 905 code, maybe 78 Mini or late Moke? (8)Engine # 99H834AJ/H4869 late clubman 998 ADR27A Air pump engine, late 76? (9)Engine # 99H119/H1082 late clubman 998 MiniMatic. The code is too early to be a Clubman. (10)Engine # 99H860AJH003068 late clubman 998 I have nothing for the 860 code. (11)Engine # 9YA/Ta/H7996 mini deluxe 998 Yep (12)Engine # 99H834AJH008690 late clubman 998 ADR27A Air pump engine, late 76? (13)Engine # 10Y/Ta/H36977 mini K Morris 1100 from about 65, not Mini K (14)Engine # 10YF/U/H9041 Moke about 1970 (15)Engine # 10004672 clubman 1100 Mini 1100 or Mini 1100 Van (poverty Clubman/Van) about 1972 (16)Engine # 100112389 clubman 1100 Clubman, late 72 early 73 (17)Engine # 1015/10875 clubman 1100 This universal code covers all Leyland Mini and Mini S and vans and Mokes up till Zetland closed and the first few months of Enfield, so 74 and 75. (18)Engine # 10Y/Ta/H56233B mini K Morris 1100 from about earyy 67, not Mini K |
Author: | Kennomini [ Mon Jul 13, 2009 7:01 pm ] |
Big thank you morris that will give me a good idea on what I've got. Morris 1100 wrote: (1)Engine # V7I786 P (either a P or a 10) Victorian police issue number, issued in 1986, could be anything Yep I noticed yesterday this has an 1100 stamp on the back of the block so 1098cc
(6)Engine # 99H33AAJH(either a U or a 0)11655 late clubman 998 ADR27A Air pump engine, late 76? The A in the engine number should be a 4I thought it could have been a 4 but it looks so much like an A ![]() |
