estapol wrote:
hey guys and gals
i was just taking off my rear number plate flapper mijiggy
and managed to round out a screw......... (feel quite stupid now)
anyone got any hints on drilling out screws before i go dig myself a bigger hole.
Hoba
Use penetrating oil before starting.
Drill it from the back so when the drill grabs the screw it will wind out.
See if you can get a pair of vice grips on the screw.
Use some heat with a heat gun if you can.
Drill with a small drill first and make sure it runs straight.
Move to the next size drill if you have got the first one to run straight,
You may be able to cut a slot in the screw with a dremmel and use a flat screwdriver (It may even work from behind)
