moke floor question..........
https://www.ausmini.com/forums/viewtopic.php?f=2&t=55155
Author:  Blunder [ Wed Jul 15, 2009 6:29 pm ]
Post subject:  moke floor question..........
Where the front subframe meets the footwell is it reinforced on a moke!?
Does anyone have underside picture of where rear of front subframe mounts!?>
thanks
Author:  mattsmadmini [ Wed Jul 15, 2009 6:32 pm ]
by 2 sheets of metal being overlapped... sure... :lol:
Author:  Kennomini [ Wed Jul 15, 2009 6:53 pm ]
I thought their was a box section down their somewhere but I'm not sure if it's the same area.
Author:  Timbo [ Wed Jul 15, 2009 9:09 pm ]
Yep, there's a box section there, sticks down about 2 - 2 1/2 cm at the front. Thats why there are holes in each footwell with one of the subframe mounting bolts down them.
Author:  drmini in aust [ Wed Jul 15, 2009 9:11 pm ]
My `79 Moke has 5 patch layers above that... :cry: :P
I will fix it, when I get time and a round tuit...
Author:  TheMiniMan [ Wed Jul 15, 2009 9:17 pm ]
Yeah, the moke floors are an inch "higher" than the mini floor pans,,, so there is a step "up" from the rear mounting point of the front frame, & yeah it`s sort of a box section where it mounts
Author:  david rosenthal [ Wed Jul 15, 2009 9:22 pm ]
If you want to look at my 67 moke at the set up your welcome. One side is still original and the other I have repaired/replaced. Both had some rust between the metal overlap
