It is currently Mon Aug 18, 2025 7:17 pm
PostPosted: Wed Jul 15, 2009 8:41 pm
ive pulled my block apart on the little 998 i had sitting around and it looks like it was rebuilt fairly recently, the crank has been balanced and the rods and bearings look pretty good.. i want to put it together just to use while i build a good big bore engine. i can still see the previous hone marks.. can i get away with just having it honed and putting it together again with new rings.. i dont really see the point in spending the extra money on a motor that is just going to be used inbetween engines if its not required
Potato
PostPosted: Wed Jul 15, 2009 8:56 pm
Get somebody to measure the bores, top and bottom. If only worn .001" or so a hone job and rings will work. For a while. Not as good as a rebore and new oversize pistons.
PostPosted: Thu Jul 16, 2009 7:33 pm
ok, so if i was to rebore and everything, what sort of specs should i be telling my machinest to bore it to. also what pistons should i fit, flat tops?
ive been allowed to build this engine so its fairly nice, so let me know what to get to get a 998 going nicely on the road..
sean
Potato
PostPosted: Thu Jul 16, 2009 7:52 pm
sean
I would definitely use flat tops, it's hard to get decent compression in a smallbore (with a reshaped combustion chamber) otherwise.
Hypatec +.080" pistons are good value, and you can still bore to +.100" or +.120" later.
http://www.minisport.com.au/prod1092.htm
PostPosted: Thu Jul 16, 2009 7:56 pm
sweetness 8) so i just tell the guy to bore it out +.080"? im new to the whole measurments game
edit : sorry the pistons are held with circlips to the gudgeon pins.
Potato
PostPosted: Thu Jul 16, 2009 7:58 pm
These Hypatec smallbore pistons all have circlips.
If you don't like them or want to rev it hard, any decent engine builder can make you up some PTFE buttons instead. These have to be made to suit the piston and pin, so they are a nice neat fit.
If you use circlips, always fit them with their sharp edges OUTWARDS.
PostPosted: Thu Jul 16, 2009 8:01 pm
Isn't the way to do it normally to give the machinist the piston and say make it fit? instead of them boring it out to a dimension and hoping its all sweet? You should probably also give them the rings so they can check the gap. Or do people just chuck the rings in out of the box usually?
PostPosted: Thu Jul 16, 2009 8:02 pm
im not going to be revving the guts out of it.. nothing more the prolly 5 grand at a serious push otherwise just the normal 2-3500rpm..
Potato
PostPosted: Thu Jul 16, 2009 8:05 pm
This space for rent
Yes you will, it's a 998 :lol: They spin so sweetly, you'll be at 7 grand before you know it :D
PostPosted: Thu Jul 16, 2009 8:07 pm
Yep, you are right on both counts.
PostPosted: Thu Jul 16, 2009 8:08 pm
im a p plater so 5000 rpm probably means 7 lol, just like when you tell the police your speedo said you were doing 100 when you were doing 130.. :roll: :wink:
Potato
PostPosted: Thu Jul 16, 2009 8:17 pm
ah ok, seems like the logical option, obviously why i didnt think of it :lol:
cheers for your help everyone
Potato
PostPosted: Thu Jul 16, 2009 8:23 pm
Go the 100" ups :D , get a fun grind cam, get a 202 head and put some slightly bigger valves.....blah blah blah.....it will sing :!: we have the technology :!:
PostPosted: Thu Jul 16, 2009 8:25 pm
yes but how far do i want to go for a motor between motors if that makes sense, i want to keep all the extra money that doesnt have to be spent for a twin cam engine later on. id be happy with a nice reliable little 998 to keep me going for 6 months or so
Potato
PostPosted: Thu Jul 16, 2009 8:30 pm
build a boggo +20" 998 then.....or go the whole hog now and bolt on the new head later.
Users browsing this forum: No registered users and 313 guests
