twin su manifold,carbies to close to extractors?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=55167
Author:  osk80 [ Wed Jul 15, 2009 10:38 pm ]
Post subject:  twin su manifold,carbies to close to extractors?
I have manifold part no aeg 347,and the bowls sit very close to the extractors . i have a spacer onbetween carby to manifold. Do i need / can i get wider spacers?
thanks up front.
Author:  drmini in aust [ Wed Jul 15, 2009 10:54 pm ]
Just use 2 spacers. This adds volume and length to the inlet tract too. Better for torque.
Author:  mini_mad_matt [ Thu Jul 16, 2009 8:13 pm ]
Should also have a heat shield too shouldnt it?
Author:  osk80 [ Thu Jul 16, 2009 8:45 pm ]
I got a pair of spacers from a MG specialist today.Now it looks like i'll have to get longer studs or try bolts , its been segested to use unc threaded bar cut to length. any idears?
Author:  drmini in aust [ Thu Jul 16, 2009 10:13 pm ]
Yep UNC threaded rod is fine.
You can also use long UNC setscrews (ie fully threaded bolts) from Supercrap, and cut the heads off. These are Grade 5 hi-tensile steel.
