It is currently Wed Aug 06, 2025 8:14 am
 Post subject: Cutting up bodywork
PostPosted: Thu Jul 16, 2009 8:35 am
Does anyone know if any strengthening of the body is required on a mini when choppin it up into a ute? Been considering giving it a go but if i have to engy it i wont bother, cant afford that sorta stuff atm.
Thanks, Matt.
PostPosted: Thu Jul 16, 2009 8:41 am
If you aren't going to do the job properly, don't do it at all.
I've seen too many minis ruined because somone cut the roof off and abandons the project later because they can't get it engineered because the job isn't done right.
PostPosted: Thu Jul 16, 2009 8:51 am
I would do it properly, and I can do it properly, just want to know if it needs to be engineered or not. If it does, I cant afford to do it so it'll stay the way it is.
PostPosted: Thu Jul 16, 2009 8:57 am
Yes it would have to be engineered.
PostPosted: Thu Jul 16, 2009 8:59 am
Yes it needs to be engineered - its changing the structure and the structural loads.
An authorised engineer should be the first port of call because if its not done to their standards then its just another wrecked mini.
Mike
