It is currently Wed Aug 06, 2025 7:31 pm
PostPosted: Wed Jul 15, 2009 10:38 pm
I have manifold part no aeg 347,and the bowls sit very close to the extractors . i have a spacer onbetween carby to manifold. Do i need / can i get wider spacers?
thanks up front.
PostPosted: Wed Jul 15, 2009 10:54 pm
Just use 2 spacers. This adds volume and length to the inlet tract too. Better for torque.
PostPosted: Thu Jul 16, 2009 8:13 pm
Should also have a heat shield too shouldnt it?
PostPosted: Thu Jul 16, 2009 8:45 pm
I got a pair of spacers from a MG specialist today.Now it looks like i'll have to get longer studs or try bolts , its been segested to use unc threaded bar cut to length. any idears?
PostPosted: Thu Jul 16, 2009 10:13 pm
Yep UNC threaded rod is fine.
You can also use long UNC setscrews (ie fully threaded bolts) from Supercrap, and cut the heads off. These are Grade 5 hi-tensile steel.
Users browsing this forum: Bing [Bot] and 71 guests
