It is currently Sun Aug 03, 2025 11:23 pm
PostPosted: Fri Jul 17, 2009 9:33 am
Hi Guys
I have nearly completed my clubman and i am up to the stage of adjusting the rear ride height (HI-LOs). now i have done some searches on this but couldn't find much. when lowering the rears, the rubber doughnut? gets really loose in its housing, i am concerned that it will fall out if i drive over a bump.
PostPosted: Fri Jul 17, 2009 9:46 am
When your car is set this low, you need to be careful to guide the rubber cone into its housing as you lower the car onto its wheels.
I have never had any trouble with it falling out, and my race car lifts rear wheels regulary. I do run a rear sway bar though which may help to hold it in.
I don't think you will have any trouble with a road car providing you keep all of the wheels on the ground i.e the suspension is loaded at all times.
PostPosted: Fri Jul 17, 2009 9:50 am
you cold try a leather strap from the arm to the subframe so the doughnut doesn't fall out
