adjustable suspension help https://www.ausmini.com/forums/viewtopic.php?f=2&t=55204 |
Author: | SuperClubby [ Fri Jul 17, 2009 9:33 am ] |
Post subject: | adjustable suspension help |
Hi Guys I have nearly completed my clubman and i am up to the stage of adjusting the rear ride height (HI-LOs). now i have done some searches on this but couldn't find much. when lowering the rears, the rubber doughnut? gets really loose in its housing, i am concerned that it will fall out if i drive over a bump. Cheers |
Author: | Number86 [ Fri Jul 17, 2009 9:46 am ] |
When your car is set this low, you need to be careful to guide the rubber cone into its housing as you lower the car onto its wheels. I have never had any trouble with it falling out, and my race car lifts rear wheels regulary. I do run a rear sway bar though which may help to hold it in. I don't think you will have any trouble with a road car providing you keep all of the wheels on the ground i.e the suspension is loaded at all times. |
Author: | justfanginaround [ Fri Jul 17, 2009 9:50 am ] |
you cold try a leather strap from the arm to the subframe so the doughnut doesn't fall out |
