do i have pressure
https://www.ausmini.com/forums/viewtopic.php?f=2&t=55208
Author:  carter [ Fri Jul 17, 2009 1:14 pm ]
Post subject:  do i have pressure
hey boys just wandering if i have oil pressure to start my new motor i turn it over and no oil is coming out of the oil pressure guage hole and also i filled the pipe from the filter to the block with oil turned it over and then oil started coming out or the block where that pipe screws in does this mean i have oil pressure just a bit hectic to start it if i dontbhave pressure....thanks in advance
Author:  superSeven [ Fri Jul 17, 2009 3:52 pm ]
Post subject:  Re: do i have pressure
which direction did you turn it over? to reverse prime the oil pump, you have to turn the engine over backwards.
Author:  carter [ Fri Jul 17, 2009 6:21 pm ]
turn it over with key.
Author:  mini-dunger [ Fri Jul 17, 2009 6:54 pm ]
do you have a capilary Oil gauge?
Author:  carter [ Fri Jul 17, 2009 9:37 pm ]
i have a guage that screws into the block. will it do any damage if i start it and see if i get pressure with my guage if nothing in the first 5 seconds then turn it off.?
Author:  850man [ Fri Jul 17, 2009 10:01 pm ]
screw your gauge in and turn the motor over (with the spark plugs out)untill you get oil pressure. the sound will change when it pumps up too. Shouldnt do any damage turning over with the key, i do it all the time. Also a tip is to heat the oil up (in a bucket of hot water) before you poor it in & fill the radiator with hot water, this warms everything up in preperation for the first start.
Author:  i got a mini [ Fri Jul 17, 2009 10:06 pm ]
i am his bro and he got told to start the motor and run it and if he dont get oil pressure in the first 5 seconds turn it off this good or bad
Author:  sgc [ Fri Jul 17, 2009 10:32 pm ]
I wouldn't start a new motor until you've got proven oil pressure.
You can get 30 PSI on the starter motor with the plugs out, enough to know that your pump is primed and working. Don't start and run it, because then you're putting load on the bearings and unless you've got pressure, you're going to cause wear.
When I built my first engine as a teenager, I forgot to fit the oil pump gasket and of course couldn't get pressure. In my naiivety I got the engine started and let it run for probably 20 seconds or so, waiting for the oil pressure to come up. It didn't, of course, and that turned into a lemon of an engine...
Take the oil pressure relief valve out and squirt oil into the pump that way (while slowly turning the engine over backwards) to prime it. Refit the valve, then turn the motor over on the starter without the plugs.
Author:  peterw [ Sat Jul 18, 2009 12:50 am ]
If you start it without oil pressure the motor may survive but you can seriously affect the life of the bearings. Mini bearings don't have a long life (compared to modern cars) anyway. Safer to crank it on the starter with the spark plugs out.
Pete
Author:  drmini in aust [ Sat Jul 18, 2009 7:53 am ]
I prime the pump throught the banjo bolt hole, then leave that bolt slightly loose and crank it (plugs out) until oil flows out. Then I tighten it and crank until it comes out the gauge/sender hole in the block.
Once you get that, all is good... put the plugs in.
Author:  carter [ Sat Jul 18, 2009 1:18 pm ]
ok thanks all for ya help.
