Help! - Wheel bearing lock nut - Melbourne https://www.ausmini.com/forums/viewtopic.php?f=2&t=55235 |
Author: | nullarbor express [ Sat Jul 18, 2009 3:39 pm ] |
Post subject: | Help! - Wheel bearing lock nut - Melbourne |
Hi all, I need a castelated nut that goes on the wheel bearing axle (left rear) of an 850 Im in Brunswick - if anyone has one they dont mind parting with and lives near enough (pretty much anywhere in metro Melb...) please PM me or call me on 0431 034 700 and I will pick up tomorrow (Sunday) Cheers, Bryan |
Author: | cush [ Sat Jul 18, 2009 3:44 pm ] |
Just use Loctite and a washer. It will last you until the day you die. |
Author: | Mick [ Sat Jul 18, 2009 4:13 pm ] |
They can be had from any bolt shop, but I can't tell you what size the thread is. I bought two front nuts from Coventrys a few months back, they were twice the quality of the new ones with the kits for 11 dollars per side. edit....but that side would be the wrong thread direction I am thinking........I've got a right hand threaded nut over here in point cook..I think you are after a left hand thread |
Author: | floss [ Sat Jul 18, 2009 5:13 pm ] |
I got mine from northern mini a few months ago. They will not open till monday so that might not help you. Where in Brunswick are you ? I am in Coburg and haven't seen your mini on the roads ( saw it at mini 50 though) |
Author: | nullarbor express [ Sun Jul 19, 2009 12:43 am ] |
Mick wrote: They can be had from any bolt shop, but I can't tell you what size the thread is.
I bought two front nuts from Coventrys a few months back, they were twice the quality of the new ones with the kits for 11 dollars per side. edit....but that side would be the wrong thread direction I am thinking........I've got a right hand threaded nut over here in point cook..I think you are after a left hand thread Yes ... need the pne with the opposite thread because i did a stupid thig removing it! Put th espanner on and tried to undo it... though S**T this is tight! So I tried a bit harder and stripped it! The thread on on the axle is still perfect but the nut stripped! Idiot! |
Author: | Mick [ Sun Jul 19, 2009 12:59 am ] |
Not the first to do it I'll tip... |
