It is currently Sat Jul 26, 2025 1:23 am
PostPosted: Sat Jul 18, 2009 3:39 pm
Hi all,
I need a castelated nut that goes on the wheel bearing axle (left rear) of an 850
Im in Brunswick - if anyone has one they dont mind parting with and lives near enough (pretty much anywhere in metro Melb...) please PM me or call me on 0431 034 700 and I will pick up tomorrow (Sunday)
Cheers, Bryan
1964 Morris 850 and some!!
PostPosted: Sat Jul 18, 2009 3:44 pm
Just use Loctite and a washer.
It will last you until the day you die.
PostPosted: Sat Jul 18, 2009 4:13 pm
They can be had from any bolt shop, but I can't tell you what size the thread is.
I bought two front nuts from Coventrys a few months back, they were twice the quality of the new ones with the kits for 11 dollars per side.
edit....but that side would be the wrong thread direction I am thinking........I've got a right hand threaded nut over here in point cook..I think you are after a left hand thread
PostPosted: Sat Jul 18, 2009 5:13 pm
I got mine from northern mini a few months ago. They will not open till monday so that might not help you.
Where in Brunswick are you ? I am in Coburg and haven't seen your mini on the roads ( saw it at mini 50 though)
PostPosted: Sun Jul 19, 2009 12:43 am
Yes ... need the pne with the opposite thread because i did a stupid thig removing it! Put th espanner on and tried to undo it... though S**T this is tight! So I tried a bit harder and stripped it! The thread on on the axle is still perfect but the nut stripped! Idiot!
PostPosted: Sun Jul 19, 2009 12:59 am
Not the first to do it I'll tip...
Users browsing this forum: Bing [Bot] and 109 guests
