It is currently Thu Aug 21, 2025 1:55 pm
 Post subject: Locating VIN number
PostPosted: Wed Jul 22, 2009 4:55 pm
Hello all,
Finally bought my first Mini which is a 65 Deluxe :)
My problem is I am trying to get a RWC but need to locate the chassis/VIN number, can anyone assist? Tried googling and searching on the forums but can't find anything.
Thanks
PostPosted: Wed Jul 22, 2009 5:19 pm
There should be a plate on the firewall on the drivers side and a number on the radiator shield.
PostPosted: Wed Jul 22, 2009 5:33 pm
I found the firewall plate and also found the chassis number behind the radiator. Took awhile for me to spot the radiator one! :shock:
The chassis number on the paperwork is M251105, however on the on the chassis itself it is M2511, missing the last two numbers.
Sorry, I am very new to the mini world.
PostPosted: Wed Jul 22, 2009 5:51 pm
The car number for a 65 Deluxe is stamped on the firewall near the master cylinders. It will be a four or five digit number with no letters. The ID plate on the firewall has the full car number with prefix as well as the engine number and body colour. It should be something like YMA2S2*****.
The number on the radiator shroud panel is the body number. It is not supposed to be used for rego, they are supposed to use the car number.
PostPosted: Wed Jul 22, 2009 5:54 pm
For a '65 model, I believe the car no which is stamped on the firewall behind the clutch/brake m/cyl should be used, not the body no which is stamped on the radiator shroud. These no.s are normally about 500 different.
1967 Morris Mini Deluxe
1927 Austin 7
PostPosted: Wed Jul 22, 2009 6:09 pm
Ahhh ok. It's just that the rego sticker had the number behind the radiator and my mechanic was just making sure.
Thanks heaps guys! :)
