It is currently Tue Jul 15, 2025 2:20 am
 Post subject: bigger pedal
PostPosted: Mon Mar 14, 2005 8:25 pm
can anyone tell me where i can acquire a paddy hopkirk or similar accelerator pedal as i am sick of my big toe slippnig off the normal one even if i am only driving up and down the driveway....
thanks
PostPosted: Mon Mar 14, 2005 8:28 pm
They pop up on ebay quite often.
PostPosted: Mon Mar 14, 2005 8:30 pm
yeh i was bidding on one but it got too expensive for me
waqs just wondering if theres a place that sells them at a reasonable place?
PostPosted: Mon Mar 14, 2005 8:47 pm
Minispares thats where I got mine from, make sure you get some nylock nuts or some locknut as the nuts vibrate loose
PostPosted: Mon Mar 14, 2005 8:48 pm
Dunk your foot in a cold pool to shrink it.
That will make it easier to move around on the pedals.
PostPosted: Mon Mar 14, 2005 8:56 pm
I substitute an early (square) brake or clutch pedal pad on the accelerator pedal, just cut them off and weld on, then use the std rubber brake/clutch pad. Been doing this for years, and doesn't look out of place. Steve
PostPosted: Mon Mar 14, 2005 9:04 pm
Why not just make one up? Peice of checker plate...few holes. That's my plan.
PostPosted: Mon Mar 14, 2005 9:06 pm
i got mine from UK ebay for 10 quid, including pedal pads too 8)
PostPosted: Mon Mar 14, 2005 9:36 pm
can you get stuff from minispares without a credit card?
is it easy or not?
and ebay UK how do you pay when the currency is different?
PostPosted: Mon Mar 14, 2005 9:43 pm
sign up for PayPal to pay via UK ebay. It's free. You transfer money from your account to paypal, then it gets converted, then pays the seller.
Pretty easy once set up.
PostPosted: Mon Mar 14, 2005 10:04 pm
might try that, i thought you needed a credit card for pay pal.
so how bout minispares and others like that, is there any way you can get stuff without a credit card..... dad wont let me use his...
PostPosted: Mon Mar 14, 2005 10:14 pm
I have delt with Mary (somthing) on Ebay UK and have found Great.
I know I have here Area somewhere..I need to buy a few things so I'll fint It
Paddy Hopkins pedals..Some like Some disk Like....
Just please make sure its up the right way :wink:
One of the first things I put on Morris
PostPosted: Tue Mar 15, 2005 6:24 am
I've got an almost new one here, we took it off Barney after the wife and I both almost put the car thru a hedge! :shock:
Bloody things- I hate 'em.
No idea what it's worth.. make me an offer if you want it. :wink:
PostPosted: Tue Mar 15, 2005 8:39 am
Agree with you Kev.
I had one for a while but found it hard to stop. When you hit the brake pedal you also hit the throttle. Sort of complicates things a bit when you are trying to stop. I take a size 9 shoe so anybody with a larger foot wil be in real strife.
They are bloody dangerous and should be done away with.
For those with slippery feet a Morris Minor throttle pedal is a similar size to a Mini and uses a rubber pad so it may fit a Mini.
Regards
RonR
PostPosted: Tue Mar 15, 2005 10:17 am
sorry just had to pick on you for that one, we all knew what you meant.
for me, bigger pedals would be a natural disater! Ron said earlier he has a size 9...i'm on size 11/12 here people. sometimes have a bit of hassle braking without stepping on my other foot (on clutch) or rubbing my shoe on the steering column. my right shoe is worn down a little bit where it rubs...
78 Leyland Mini - Prince
