It is currently Wed Jul 16, 2025 10:06 pm
 Post subject: Update:
PostPosted: Tue Mar 08, 2005 8:31 am
Just done some more updating on the web site, I've added some newer pics, you can clearly see some of the rust patches that I've yet to deal with. I'm try to get bogging done on the rear drivers quarter panel, not easy :( .
http://members.dodo.com.au/~thechairman
PostPosted: Tue Mar 08, 2005 8:36 am
I'd be MIG welding these....
Did you say you can't get access to a welder? Or was that someone else?
Just as a matter of interest to people....my father in law bought a Gas MIG welder. I had only used a gasless previously. The gas MIG welds much nicer than the gasless. I did notice this when using Kev's gas MIG recently too :mrgreen:
You HAVE to use PPG Etch Primer on that shell. You have done a brilliant job stripping it to metal, and the PPG Etch Primer is so good at bonding to metal!!!! Well done!!
PostPosted: Tue Mar 08, 2005 8:42 am
It was I, I didn't really want to hire a mig welder because of the amount of work, I can't really weld and cost. Dad has an Arc welder, but its not adjustable. I thought I might be able to fibreglass those holes, but I've decided on welding them.
Etch primer, I've got some from a local Panel Works who does use PPG, but I'd say the etch primer is a cheaper brand.
PostPosted: Tue Mar 08, 2005 8:52 am
the reason I suggest welding over glassing is because that area is prone to rusting, and damp. Bog will swell with moisture and bubble. Glassing might be ok, but for best long term repair - weld it.
PostPosted: Tue Mar 08, 2005 8:59 am
I would be cutting it all away until got to clean metal, then weld a patch in.
MIG welding over rusty holes is not much more permanent than fibreglassing it. :wink:
PostPosted: Tue Mar 08, 2005 9:01 am
So just angle grind the crap out of it and then weld a patch of sheet metal in the hole??
PostPosted: Tue Mar 08, 2005 9:08 am
Correct. You can then grind the welds, beat it level (or just below) and finish with a skim of filler.
PostPosted: Fri Mar 18, 2005 10:20 am
Woohoo, got me a lend of a Mig welder, I think its gasless but that won't matter will it?
No I just need to pick up the old 850 shell that I'm gonna use for panels. I have the old green Deluxe, but after looking at it and cleaning it out the other day I would rather do it up as well, it seems really good condition (well, some miner dents etc, rusted floor)
PostPosted: Fri Mar 18, 2005 10:25 am
mate i hope its a dry place there
all that rubbing back mustve been hard work
excellent work
do you know how to weld?
Inconspicuously Conspicuous
PostPosted: Fri Mar 18, 2005 10:30 am
Generally its pretty hot and dry, but during summer its supposed to be our wet season I think, but we havn't had much rain.
As to welding, not really, I get the general idea, I didn't get to do it at school and I only did Metalwork in Yr10 not Yr9 (which is where they learnt some I think). Dad know's how to arc weld, so he can help me out. And my boss at work knows how to weld, so if I get stuck :D
PostPosted: Fri Mar 18, 2005 10:39 am
wheres Moree in nsw?
yeh you'll get the hang of it
i made a complete set of security bars for a house
3 days, 15 windows, 80 metres of mild steel, one arc welder
no experience
good thing is, we saved $900
PostPosted: Fri Mar 18, 2005 10:48 am
Yeh Moree is country nsw, its 120kms from Goonderwindi, 9 hours from Sydney, 3.5 Hours from Tamworth.
PostPosted: Fri Mar 18, 2005 10:49 am
righto
hey tamworth is where Adam (adsmini) lives
have you met up with him yet
PostPosted: Fri Mar 18, 2005 11:04 am
Nah, and I don't ever go to Tamworth anyway, I normally go to Toowoomba when I go away.
Gasless is very convenient, but I think a gas MIG produces better welds. That's my experience anyway.
Users browsing this forum: Bing [Bot] and 89 guests
