It is currently Sun Aug 03, 2025 1:42 pm
 Post subject: Head Gasket leak
PostPosted: Thu Jul 23, 2009 5:43 pm
I've had the head off the 850, and after re install and a couple of short runs, i find fluid seeping from head gasket.
I installed a monotorque gasket, tightened the head in proper sequence, have re tensioned the head in proper sequence. My assumptions are, there may be some dirt on gasket or may have a warped head. When i take the head off, can i clean and re use head gasket?
Any other possible senarios?
Suggestions appreciated. Thanks Anthony.
PostPosted: Thu Jul 23, 2009 6:17 pm
Head gaskets are a single use item, once you squish em thats it (Like snails :lol: ). Thats just my opinion any way
 Post subject: Re: Head Gasket leak
PostPosted: Thu Jul 23, 2009 8:17 pm
monotorque does mean torque once, so you shouldn't need to retension, and no, you won't be able to re-use the gasket
the head and block should be clean enough to eat off - there shouldn't be any doubt about whether or not there was dirt on the gasket. Did you take the head off for a particular reason? did it overheat?
also, how well do you trust your torque wrench - if it's a supercheap etc. brand then the actual torque may be way off
PostPosted: Thu Jul 23, 2009 9:53 pm
My engine builder told me to run it around a little bit on water before you use coolant as it can find its way into bores,oil galleries before gasket seals up properly
Users browsing this forum: No registered users and 65 guests
