gears crunching when changing down gears?? https://www.ausmini.com/forums/viewtopic.php?f=2&t=55409 |
Author: | kudos to minis [ Thu Jul 23, 2009 7:03 pm ] |
Post subject: | gears crunching when changing down gears?? |
im worried only just started happening , changes up gears no problems but down into 3rd or 2nd it crunches and also first is very hard 2 find not sure if its normal or not??? i tryed moving the carpet bhind the clutch pedel but dont think it made a difference ![]() |
Author: | blueminivan [ Thu Jul 23, 2009 7:06 pm ] |
Is your clutch fluid level ok? |
Author: | kudos to minis [ Thu Jul 23, 2009 7:09 pm ] |
havent checked but i will wen i find a torch |
Author: | Dylans Clubby [ Thu Jul 23, 2009 8:42 pm ] |
what are your revs when you're changing down (if you have a tacho)? try changing down a little later and see how you go. otherwise, if still crunching at low revs your clutch needs adjusting, or your synchros are wearing out (expensive...) |
Author: | kudos to minis [ Thu Jul 23, 2009 9:47 pm ] |
ok its not flud level, and it now only seems 2 be doing it sometimes, plus the clutch feels soft n then hard like it changes from when it warms up or stop and starting i guess dunno if thats rite? |
Author: | TheMiniMan [ Thu Jul 23, 2009 9:49 pm ] |
Probably a broken offf ball on the bottom of the clutch arm Pull the arm off the end of the engine & inspect the condition of the ball on the bottomn of it |
