It is currently Tue Jul 29, 2025 8:16 pm
PostPosted: Thu Jul 23, 2009 7:22 pm
Hi all, we need to drill out spot welds so we can remove panels, what is the name of the drill piece that is the best tool for the job? and where would we purchase one from?
Any other tips when dealing with spot weld removal?
It's not the size of the dog in the fight, but the size of the fight in the dog!!
1976 Mini SS
1971 Mini Ute (Custom) - really hubby's but I will claim half :)
1976 Mini SS Shell
Oh and an 850 shell waiting for our dear son to start his resto!
PostPosted: Thu Jul 23, 2009 7:35 pm
At work we use wurth spot weld drill bits. They are strong and last well in normal steel car panels but not so well in new cars with hardened steel in them.
You must use a slow revving drill and best to also use a cutting oil as well.
Only go through the outer panel( if you can stop in time)
Is fairly easy once you get used to it just take your time.
Phil
PostPosted: Thu Jul 23, 2009 7:38 pm
as far i know they are called spot weld drill bits
you can get them through "Wurth"
you may requre a chizel with the edge on the side. insded of the tip
like a knife you slide it along inbetween the panels to help break the join you hit the side with a hammer to split the join
that is what we do at my panel beating shop
or you can weld straight through them and weld up the hole later
a tip is to screw the panels together withself tapping screws as you cant get a clamp everywere and weld up the holes later
1969 Blue Mini K, 1330cc, Weber 45, polished aluminum roll cage, Race seats, 4 point harness, full rewire incorporating 8 fuses, 6 relays and new headlights :) just needs tyres front shocks and a windscreen til re-register
PostPosted: Thu Jul 23, 2009 8:18 pm
High heel ninja
Phil
How many new cars have "Hardened" stell in them???
Doogie
PostPosted: Thu Jul 23, 2009 8:23 pm
in so many ways I wish I got that job at Wurth :twisted:
PostPosted: Thu Jul 23, 2009 8:24 pm
Phil
Doogie
How many cars have stell in them at all?
and who the hell is doogie?
PostPosted: Thu Jul 23, 2009 9:07 pm
All new cars now have hardened steel and it really sucks to repair them if they are bent in these areas :roll: . Mostly in the rails, pillars and inner sill panels to help protect the occupants in an accident.
There are many different grades of hardened steel too. Most older spot welders are now no good to repair these new cars.
Makes me wonder WHY I became a panel beater sometimes but hopefully in the next year I'll just be restoring older cars like THE MIGHTY MINI. LOL. Just now starting to restore a 1908 reo car. It's mostly timber so will be a bit different than what I'm used to working on. 8)
Phil
PostPosted: Thu Jul 23, 2009 10:06 pm
MMMMMMM STELL is aok :?
PostPosted: Thu Jul 23, 2009 10:10 pm
we have been warned that future cars are coming out with an alloy steel equal to tungsten in strength
PostPosted: Fri Jul 24, 2009 10:12 am
But will they last 50 years?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Jul 24, 2009 11:12 am
Yes, if you don't crash them!
Some new cars also have foam filled pillars and sills for extra strength.
Now that would be a right bastard to work on.
PostPosted: Fri Jul 24, 2009 12:24 pm
Minis had that in 1959.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Jul 24, 2009 1:01 pm
sutton also make a spot weld cutter drill bit - i got mine from gasweld.
Make sure you use a punch to put an indent into the middle of the spot weld to give the drill bit something to locate in otherwise they can go "walk about"
 Post subject: Thanks
PostPosted: Fri Jul 24, 2009 8:21 pm
Thanks All for the info :D
1976 Mini SS
1976 Mini SS Shell
