Drilling out spots weld - how and what equipment? https://www.ausmini.com/forums/viewtopic.php?f=2&t=55411 |
Author: | 1976miniss [ Thu Jul 23, 2009 7:22 pm ] |
Post subject: | Drilling out spots weld - how and what equipment? |
Hi all, we need to drill out spot welds so we can remove panels, what is the name of the drill piece that is the best tool for the job? and where would we purchase one from? Any other tips when dealing with spot weld removal? |
Author: | toymini76 [ Thu Jul 23, 2009 7:35 pm ] |
At work we use wurth spot weld drill bits. They are strong and last well in normal steel car panels but not so well in new cars with hardened steel in them. You must use a slow revving drill and best to also use a cutting oil as well. Only go through the outer panel( if you can stop in time) Is fairly easy once you get used to it just take your time. Phil |
Author: | The Ranger 89 [ Thu Jul 23, 2009 7:38 pm ] |
as far i know they are called spot weld drill bits you can get them through "Wurth" you may requre a chizel with the edge on the side. insded of the tip like a knife you slide it along inbetween the panels to help break the join you hit the side with a hammer to split the join that is what we do at my panel beating shop or you can weld straight through them and weld up the hole later a tip is to screw the panels together withself tapping screws as you cant get a clamp everywere and weld up the holes later |
Author: | doogie [ Thu Jul 23, 2009 8:18 pm ] |
toymini76 wrote: At work we use wurth spot weld drill bits. They are strong and last well in normal steel car panels but not so well in new cars with hardened steel in them.
You must use a slow revving drill and best to also use a cutting oil as well. Only go through the outer panel( if you can stop in time) Is fairly easy once you get used to it just take your time. Phil How many new cars have "Hardened" stell in them??? Doogie |
Author: | gafmo [ Thu Jul 23, 2009 8:23 pm ] |
in so many ways I wish I got that job at Wurth ![]() |
Author: | 1310/71 [ Thu Jul 23, 2009 8:24 pm ] |
doogie wrote: toymini76 wrote: At work we use wurth spot weld drill bits. They are strong and last well in normal steel car panels but not so well in new cars with hardened steel in them. You must use a slow revving drill and best to also use a cutting oil as well. Only go through the outer panel( if you can stop in time) Is fairly easy once you get used to it just take your time. Phil How many new cars have "Hardened" stell in them??? Doogie How many cars have stell in them at all? and who the hell is doogie? |
Author: | toymini76 [ Thu Jul 23, 2009 9:07 pm ] |
All new cars now have hardened steel and it really sucks to repair them if they are bent in these areas ![]() There are many different grades of hardened steel too. Most older spot welders are now no good to repair these new cars. Makes me wonder WHY I became a panel beater sometimes but hopefully in the next year I'll just be restoring older cars like THE MIGHTY MINI. LOL. Just now starting to restore a 1908 reo car. It's mostly timber so will be a bit different than what I'm used to working on. ![]() Phil |
Author: | mini maxx [ Thu Jul 23, 2009 10:06 pm ] |
MMMMMMM STELL is aok ![]() |
Author: | The Ranger 89 [ Thu Jul 23, 2009 10:10 pm ] |
we have been warned that future cars are coming out with an alloy steel equal to tungsten in strength |
Author: | michaelb [ Fri Jul 24, 2009 10:12 am ] |
Quote: we have been warned that future cars are coming out with an alloy steel equal to tungsten in strength
But will they last 50 years? |
Author: | awdmoke [ Fri Jul 24, 2009 11:12 am ] |
Yes, if you don't crash them! Some new cars also have foam filled pillars and sills for extra strength. Now that would be a right bastard to work on. |
Author: | Timbo [ Fri Jul 24, 2009 12:24 pm ] |
awdmoke wrote: Yes, if you don't crash them!
Some new cars also have foam filled pillars and sills for extra strength. Now that would be a right bastard to work on. Minis had that in 1959. Tim |
Author: | britishvita [ Fri Jul 24, 2009 1:01 pm ] |
sutton also make a spot weld cutter drill bit - i got mine from gasweld. Make sure you use a punch to put an indent into the middle of the spot weld to give the drill bit something to locate in otherwise they can go "walk about" |
Author: | 1976miniss [ Fri Jul 24, 2009 8:21 pm ] |
Post subject: | Thanks |
Thanks All for the info ![]() |
