FLASH LUBE FOR CARS https://www.ausmini.com/forums/viewtopic.php?f=2&t=55428 |
Page 1 of 2 |
Author: | Davo111 [ Fri Jul 24, 2009 3:43 pm ] |
Post subject: | FLASH LUBE FOR CARS |
Just a quickie, had my falcon put on gas ![]() ![]() ![]() ![]() Cheers.... |
Author: | poeee [ Fri Jul 24, 2009 3:48 pm ] |
I'm sure most people here run that or something simular. ![]() Seeing as though you can't get leaded fuel anymore. |
Author: | Davo111 [ Fri Jul 24, 2009 3:52 pm ] |
I am just curious, is it a wank or does it actually work?????? ![]() ![]() |
Author: | drmini in aust [ Fri Jul 24, 2009 4:55 pm ] |
LPG is a dry fuel, with no lube properties whatever. Flashlube was invented years ago for Holden and Falcon motors running LPG with iron heads, and no inserts. Using LPG in them wore the seats away the same as unleaded does. I have used Flashlube for years in my Minis as lead replacement, I know it works for that. But if your Ford is not an antique and has unleaded inserts already, the Flashlube won't do much except provide upper cylinder lube. It won't hurt, but it's not really needed. ![]() |
Author: | Morris 1100 [ Fri Jul 24, 2009 5:00 pm ] |
What your is your Falcon? If it is a late model I wouldn't bother. The valve seats and rings should already be up to the job. It is just another version of snake oil. ![]() |
Author: | awdmoke [ Fri Jul 24, 2009 5:06 pm ] |
Post subject: | Re: FLASH LUBE FOR CARS |
Davo111 wrote: FLASH LUBE FOR CARS
Just in case anyone was thinking of Flash Lube for goats ? ![]() |
Author: | TheMiniMan [ Fri Jul 24, 2009 5:19 pm ] |
Ohhh,,, whew!!!! & here I was thinking more along the lines of KY ![]() ![]() |
Author: | floss [ Fri Jul 24, 2009 5:31 pm ] |
awdmoke wrote: Davo111 wrote: FLASH LUBE FOR CARS Just in case anyone was thinking of Flash Lube for goats ? ![]() That is funny.. Sorry, but i haven't used it. That made me laugh though ![]() |
Author: | Gadgets mini [ Fri Jul 24, 2009 5:50 pm ] |
awdmoke wrote: Davo111 wrote: FLASH LUBE FOR CARS Just in case anyone was thinking of Flash Lube for goats ? ![]() or Camels ![]() |
Author: | Davo111 [ Fri Jul 24, 2009 6:19 pm ] |
by the look of the expert replies, I am pleased to say that Doc, appears to be the only one taking his medication, so to all the rest, go and take your pills or you will all turn into mushrooms, and you know how mushroom are made to grow. Thanks again Doc, nice to know you can be relied on... ![]() ![]() |
Author: | Timbo [ Fri Jul 24, 2009 8:58 pm ] |
I've got one of their kits in my Moke and it works OK. Its a little bit fiddly to get it adjusted right and it does actually work the wrong way. Because its 'powered' by engine vacuum more flashlube gets dispensed when manifold vacuum is at its highest (i.e. when the throttle is closed) but then when you put your foot down less gets dispensed. But apart from that its fine, I put flashlube in it and it disappears so I guess its doing its job. I suppose on an LPG vehicle its pretty hard to take the fuel cap off and pour in a little bottle of the stuff, so this would be a solution. As to whether it works or not, I wouldn't have a clue. I haven't had any noticeable valve seat recession since I fitted it, but then I didn't have any before hand either. Tim |
Author: | drmini in aust [ Fri Jul 24, 2009 9:07 pm ] |
My 1360's valves & seats are always clean and shiny now. ![]() ![]() ![]() |
Author: | Morris 1100 [ Fri Jul 24, 2009 9:10 pm ] |
And my valves are still working fine with no additives. The valve clearances have not budged. So, would you run valvemaster in a new car that was made LPG compatible? (like a Falcon?) |
Author: | drmini in aust [ Fri Jul 24, 2009 9:12 pm ] |
Morris 1100 wrote: And my valves are still working fine with no additives.
The valve clearances have not budged. So, would you run valvemaster in a new car that was made LPG compatible? (like a Falcon?) No. ![]() Your Morris 1100 has tetra ethyl lead valves, not steel.. Reco the head and see what happens. ![]() |
Author: | Morris 1100 [ Fri Jul 24, 2009 9:16 pm ] |
drmini in aust wrote: Morris 1100 wrote: And my valves are still working fine with no additives. The valve clearances have not budged. So, would you run valvemaster in a new car that was made LPG compatible? (like a Falcon?) No. ![]() Your Morris 1100 has tetra ethyl lead valves, not steel.. Reco the head and see what happens. ![]() Why reco the head, it works fine the way it is. ![]() Besides, I don't want to disturb the 43 year old head gasket. How much tetra ethyl lead would be left on the valves since it hasn't had any leaded fuel for over 10 years? |
