simon k wrote:
Matt Read reckons to bleed them with the front adjusters loose, so the pistons can move and push the air out.
the reason was way more logical than that - the bleeder hole is in the centre of the piston, which is mounted with the pistons aligned vertically. if they're adjusted up, then the topmost piston can have a bubble under it, and above the bleed hole. Un-adjusting them pulls that piston down, so the air bubble is in line with the bleeder hole
great bit of logic that one
See Matt - some of it rubs off!
hee hee,,, yep, you have it right Simon,,, days like this make it all worth while
I "RARELY" ever need to "Pump the peddle" when sorting brake bleeding issues out
Sooooo..... There`s usually at least 2x problems asociated with the average person attempting drum mbrake bleeding & adjusting,,, one of which is the adjusters rotation direction ,,, & the other is the bleeding method
i`d suggest un-adjusting the front brakes --> & un-adjusting means to turn the adjusters in the opposite direction of the forward rotation of the wheels
(don`t worry about the rears , just leave them adjusted up) ,,,
then bleed the system---> & to do that, just release all 4x bleed screws & let them drip away,,, have a cuppa & just jeep an eye on the resovoire fluid level & keep it topped up as they`re all bleeding out.
Now """IF""" no fluid comes out of a nipple then there will be some sort of blockage, maybe just some poop,,, maybe a hose is crook,,, whatever,,, so that will need addressing first & then get back to the bleeding
after you have all that done & fluid is happilly P!$$ing from all 4 wheels,,, & you`ve kept the resovoire topped up the whole time,,,, then walk around & tighten the nipples back up
then adjust up the front brakes , one at a time, till they lock the wheel,,,then back it off till the wheel turns... BUT!!!!!!!!!!!! The front brakes (if they`re twin leading shoes) will need to be adjusted the correct "way",,,
adjust up in the direction of the forward rotation of the wheel.,,, if it`s not done this way then they will tend to un-adjust themselves whilst driving along applying the brakes, each application of the peddle will un-adjust them.
so,,, """IF""" if done all that,,,, & '""IF""" everything is perfect & nothing else is wrong. then you should be able to jump into the car,,, press the brake peddle & all should be well
any problems with this method , just PM me or ring me 0407 135 656
easy-peasy
