Alternator Check https://www.ausmini.com/forums/viewtopic.php?f=2&t=55545 |
Author: | seifer [ Tue Jul 28, 2009 7:31 pm ] |
Post subject: | Alternator Check |
Guys I had my alternator fail on me. The warning light gradually got darker and darker over a few weeks. It has since died completely. Ive also thrown in a mitsubishi brand from a ford laser and a bosch from an ea falcon since and have had the same problem of no charge. They were wired up correctly. Now before I swap for a third one, is there anything I should check on the car first that could be failing or has pick and payless just sold me a couple of of duds? |
Author: | Morris 1100 [ Tue Jul 28, 2009 7:37 pm ] |
Check the light globe. |
Author: | mini maxx [ Tue Jul 28, 2009 7:59 pm ] |
Alts dont like being shelved for a long time, unbolt a freshie an use that |
Author: | Tombo [ Tue Jul 28, 2009 8:03 pm ] |
Morris 1100 wrote: Check the light globe.
Top tip, Easy check for this is to disconnect the small wire to the back of the alternator, poke a test light into it and turn on the ignition, dash light should come on. Is the connection at the start solenoid good? |
Author: | seifer [ Tue Jul 28, 2009 9:12 pm ] |
yeah the connections have been cleaned just in case and im changing batteries every couple of days (recharging the spare obviously) so its not just the globe. |
