Ok, got an 1100 with an auto engine sitting on a manual subframe and tring to lift the mini off over the front then roll the subframe & engine out. One problem - the bolty pin thing the steering column bolts onto to steer the car (sticks out through the floor bout an inch) is getting caught on the floor, in the hole it pokes through. Tried everything i can think to get it out, is there a trick to it?
Also, whats the best way to stop the lot tipping over? I've got some wood under the gearbox at the moment, hope that'll work. Any ideas?
Thanks, Matt.
