It is currently Sun Aug 03, 2025 11:23 pm
 Post subject: A+ Dizzy wiring
PostPosted: Wed Jul 29, 2009 9:02 pm
Hi All,
Been reading for a while now and i finally have a problem i can't find the answer to on this forum.
Im setting up a metro 1275 in my van and i'm unsure of the correct wiring for the dizzy.
The dizzy has two wires rather than the single usually on the A series, a white one and white with black strip. Do these just go to either side of the coil?
I've got the ignition power feed sorted but what else is required?
Also, i've read that these need a different coil, will the 1.5 ohm pulsar coil work?
If anyone has a wiring diagram they could send me that would be great.
Any help would be greatly appreciated.
Thanks
PostPosted: Wed Jul 29, 2009 9:34 pm
Put them on either sie of the coil , one way won`t make it go veroom,,, the other way will
true
PostPosted: Thu Jul 30, 2009 12:17 am
Very true, Matt :lol:
White goes to (+) coil terminal
Black/white goes to (-) coil terminal
Same with the wires from the loom (W+, B/W-).
Don't forgett to fit a coil for elec ignition. Don't know about the ohms... GCL143 would be the original coil.
PostPosted: Thu Jul 30, 2009 12:50 am
Cool,
I thought as much, i just wanted to check before doing it to avoid frying the module.
Thanks
PostPosted: Thu Jul 30, 2009 10:10 am
When you set it up for initial timing (trying to get the green light to come on), remember to take the black wire off the coil. I forgot and got a bit of a spark. :shock:
2008 Prado GXL
