Disc conversion
https://www.ausmini.com/forums/viewtopic.php?f=2&t=55555
Author:  estapol [ Tue Jul 28, 2009 8:38 pm ]
Post subject:  Disc conversion
Hey people
Thinking... just thinking bout putting disc brakes in my 76 clubby
i have 12" wheels on it so if i buy the conversion kit for it how much works involved?
i've quoted them for 1500 (on special) at minisport in adelaide.
Cheers Hoba
Author:  TheMiniMan [ Tue Jul 28, 2009 8:45 pm ]
Not much really,,, if buying from Minisport then they will come in bits (un-assembled) so you`ll have to "build them"
then fitting is basically taking from ball joints, tie rod ends & brake hoses, swap axles to the new CVs
remove as assemblys & fit the new "Assemblys" ... & then a wheel alignment
sounds easy enough hey? :-)
ok,,, so there "Is" a fair bit to do,,,, but it`s easy for me :-)
Author:  Kennomini [ Tue Jul 28, 2009 8:51 pm ]
It is relatively easy to assemble and bolt them on.
IMO a wheel alignment is not 100% necessary but it can never hurt.
Author:  Danny [ Tue Jul 28, 2009 9:59 pm ]
So what do you charge to do it, if all the parts are supplied?
Author:  TheMiniMan [ Wed Jul 29, 2009 11:41 am ]
Kenno,,, with any a drum - to - disc conversion a wheel alignment """IS""" necessary,,, if you un-bolt drum assys & then bolt disc assys on, then the toe/tracking will """WILL""" be way out
anyone who fits discs onto a car that had drums """WILL""" need a wheel alignment to at least set the "toe"
Chow, i normally charge around $200 to assemble both wheel assemblys, set up all 4x ball joints, fit & grease wheel bearings , pack & fit CV joints & boots, fit disc , pads & drive flanges together etc etc etc,,,
& then $200 to fit both assys (inc bleeding brakes) & wheel aligne it.
But!!! i always suggest fitting Hi-los, adjustable control arms & new bushes as well,,, that creats a VERY good "Package"
only cause i`m a Package sort of guy :-)
funny enough they end up turning & stopping really really well after that :-)
Author:  estapol [ Wed Jul 29, 2009 6:00 pm ]
cheers once again for the advice miniman and everyone else
have to sell my civic then i will have a little bucket of money to splash out on the beast.....
