rear trailing arm problem https://www.ausmini.com/forums/viewtopic.php?f=2&t=55573 |
Author: | dinominigt [ Wed Jul 29, 2009 4:42 pm ] |
Post subject: | rear trailing arm problem |
Hi all, I have just fitted the rear trailing arms to my moke and fitted the wheels. Passenger side is ok but on drivers side the tyre hits the rear sub frame bolt. I have already fitted a new rear shaft. The inside of the tyre is about 15 to 20 mil closer than the other side. Where the trailing arm attaches to the sub frame i have taken out the shim/spacer this makes no difference. Is there anything else that i can check THANKS Dean ![]() |
Author: | Harley [ Wed Jul 29, 2009 4:53 pm ] |
Sounds like a bent subframe. If you get an adjustable camber/castor kit that might fix the problem, unless you have two different length trailing arms! ![]() |
Author: | Mick [ Wed Jul 29, 2009 4:58 pm ] |
If you have had the trailing arms rebushed, you may have hed them reamed out of alignment as well. if the old arms weren't a problem, and the new ones are,have the bushes checked for concentricity. |
Author: | Wombat [ Wed Jul 29, 2009 6:36 pm ] |
Mick wrote: concentricity.
Author: | Mick [ Wed Jul 29, 2009 7:10 pm ] |
Its the word of the day you know ![]() That and the number 4 with the letter M according to Sesame Street Quote: con·cen·tric (kn-sntrk) also con·cen·tri·cal (-tr-kl)
adj. Having a common center. [Middle English concentrik, from Medieval Latin concentricus : Latin com-, com- + Latin centrum, center; see center.] con·centri·cal·ly adv. concen·trici·ty (knsn-trs-t) n. |
Author: | dinominigt [ Wed Jul 29, 2009 7:23 pm ] |
Thanks for the replys will go and check a few measurements. Good word of the day!!!!! |
Author: | Drexxle [ Wed Jul 29, 2009 8:12 pm ] |
the arm itself might be bent, but not visually apparent. |
Author: | TheMiniMan [ Wed Jul 29, 2009 9:35 pm ] |
More than likely the arm is bent |
Author: | moemoke [ Thu Jul 30, 2009 5:33 am ] |
If its not a bent arm then it could be a worn hole on the inner mount. |
Author: | miniDave [ Thu Jul 30, 2009 6:55 am ] |
Mick wrote: If you have had the trailing arms rebushed, you may have hed them reamed out of alignment as well. if the old arms weren't a problem, and the new ones are,have the bushes checked for concentricity.
Thought only minis use the bush? - mokes have two needle bearings. I take it that the wheels/tyres are the same and the offset are also the same on both sides? Regards |
Author: | Mick [ Thu Jul 30, 2009 7:31 am ] |
miniDave wrote: Thought only minis use the bush? - mokes have two needle bearings. You're absolutely right....they won't even accept the bronze bush if you wanted to....it won't be that then... |
Author: | Mattmini [ Thu Jul 30, 2009 8:09 am ] |
Mick wrote: Its the word of the day you know ;)
That and the number 4 with the letter M according to Sesame Street Quote: con·cen·tric (kn-sntrk) also con·cen·tri·cal (-tr-kl) adj. Having a common center. [Middle English concentrik, from Medieval Latin concentricus : Latin com-, com- + Latin centrum, center; see center.] con·centri·cal·ly adv. concen·trici·ty (knsn-trs-t) n. Whatever happened to 'dog' being the word of the day? or other simple words like that |
Author: | dinominigt [ Thu Jul 30, 2009 8:53 am ] |
Wheels are same size and rim offset is the same. Trailing arm does have roller bearings at each end Inner hole on subframe is not worn or slotted Looks like i will have to dig out another rear trailing arm, clean and paint GRRRR Thanks everyone |
Author: | Wombat [ Thu Jul 30, 2009 9:27 am ] |
When I first got the car and fitted new rear bearings and shockers I found the rear wheel on the passenger side rubbed the shocker. I used a spacer (both sides) made from a cut down brake drum to give me some clearance. I've since gone the whole hog and installed adjustable suspension all round and although not adjusted yet I am hoping I can adjust the clearance to suit without the spacer. |
