Joined: Mon Aug 23, 2004 10:07 pm Posts: 10654 Location: SE Melbourne
The engine mounts only went about half to one inch forward at around about 1993.
This was to get the throttle body on the injection cars to have better clearance on the firewall. The engines and the mounts themselves are all the same (though manual and auto boxes have different mounts).
As NG mentioned, if the 89 rover originally had a manual subframe and still does you'll need to obtain an 'auto' one. These are a couple of inches wider in the bottom for the bigger gearbox.
