DIY car trailer kit https://www.ausmini.com/forums/viewtopic.php?f=2&t=55623 |
Page 1 of 2 |
Author: | Wombat [ Fri Jul 31, 2009 9:19 am ] |
Post subject: | DIY car trailer kit |
For those who can weld here's an idea |
Author: | sports850 [ Fri Jul 31, 2009 9:24 am ] |
Nice idea but considering the work involved (and having to trust your welding skills) it seems a bit pricey . I would have thought there wouldn't be much need for this type of kit since it is all stuff you either buy over the counter (springs , axle , hubs etc) or buy and cut to length (steel) . You're basically buying the design more than the parts I guess ??? |
Author: | TheMiniMan [ Fri Jul 31, 2009 9:25 am ] |
"who",,, David,,, not how ![]() dam i`m getting picky in my old age ![]() |
Author: | Wombat [ Fri Jul 31, 2009 9:29 am ] |
and my fingers are getting dyslectic in their old age ![]() |
Author: | sports850 [ Fri Jul 31, 2009 9:32 am ] |
And I'm getting to the point of not bothering with spelling corrections in my old age ... Then again , Matt , it's "damn" , not "dam" ![]() |
Author: | awdmoke [ Fri Jul 31, 2009 9:44 am ] |
Don't underestimate the costs. I was given an old trailer which I cut and modified just to suit a mini, so no steel costs. Budget - what I actually spent: ORIGINAL FRAME COST $ nil Andy LIGHT BAR, PRE WIRED $100.00 Supercheap BEARINGS REFLECTORS JOCKEY WHEEL etc $185.87 Martins Trailer Parts 13" HOLDEN RIMS - PAIR $100.00 Avanti Tyres 13" LT TYRES - PAIR $180.00 Avanti Tyres WEIGHBRIDGE $25.00 Novacoat MISC HARDWARE $80.00 INSPECTION FEES $103.50 Two lots PAINT $ nil already had it STAMP DUTY AND LICENSE FEES $85.55 DPI TOTAL $859.92 That was for a single axle trailer. The cost of parts does add up. |
Author: | bnicho [ Fri Jul 31, 2009 9:57 am ] |
Marshall Engineering. I've bought a lot of stuff from these guys for my own trailers and caravan, partly because they are close by and partly because it's always quality gear at a decent price. I reckon it's likely to be a good kit, but you can probably pick up a second-hand trailer of similar spec complete for the same price. This trailer is overkill for towing a Mini anyway. awdmoke, some money-saving ideas. Although more appropriate to my location than yours, they may shave $150 or so off your costings - Whitworths Leisure down the street from my work have the long trailer boards for $80. - Holden 13" rims can be had for $25 each from Marshall-Eng (they had a huge stock last time I was there). Would need a scrub and paint though. - Jockey wheel, bearings and reflectors are cheap at Super-Crap. Cheers, |
Author: | sports850 [ Fri Jul 31, 2009 11:25 am ] |
awdmoke wrote: Don't underestimate the costs. I was given an old trailer which I cut and modified just to suit a mini, so no steel costs.
Budget - what I actually spent: ORIGINAL FRAME COST $ nil Andy LIGHT BAR, PRE WIRED $100.00 Supercheap BEARINGS REFLECTORS JOCKEY WHEEL etc $185.87 Martins Trailer Parts 13" HOLDEN RIMS - PAIR $100.00 Avanti Tyres 13" LT TYRES - PAIR $180.00 Avanti Tyres WEIGHBRIDGE $25.00 Novacoat MISC HARDWARE $80.00 INSPECTION FEES $103.50 Two lots PAINT $ nil already had it STAMP DUTY AND LICENSE FEES $85.55 DPI TOTAL $859.92 That was for a single axle trailer. The cost of parts does add up. I know it isn't cheap but don't forget on your list above , the bold highlighted things you would need to pay for with the trailer kit as well . |
Author: | Wombat [ Fri Jul 31, 2009 11:32 am ] |
Found this as well ![]() |
Author: | mickmini [ Fri Jul 31, 2009 5:01 pm ] |
just the steel pre-cut would be $1K |
Author: | bnicho [ Fri Jul 31, 2009 5:12 pm ] |
In Vic: - No stamp duty on trailers. - Inspection fee at VicRoads $35. A once off provided nothing is dodgy. - Number plate fee $27.50 (first registration only). - Rego for a year is $35.60. Approx $100 all in. ![]() |
Author: | awdmoke [ Fri Jul 31, 2009 5:24 pm ] |
I got knocked back the first time mostly because I didn't use stamped rated chains - that changed from the last time I made a trailer. Still cheaper in Vic. If I'd got it on my first pass it would have been $135 all in. |
Author: | bnicho [ Fri Jul 31, 2009 10:01 pm ] |
I don't think my local VicRoads have heard of stamped chains. Every time I have registered a trailer they have checked the lights, the numbers, the tyre treads and that's it. Another enlightened Victorina law: If a trailer is less than 3m long, narrower than the towing vehicle and weighs less than 200kg unladen and for private use, then you don't have to register it at all. So 90% of the 6x4 and smaller trailers are not registered. ![]() |
Author: | Morris 1100 [ Fri Jul 31, 2009 10:45 pm ] |
bnicho wrote: Another enlightened Victorina law: If a trailer is less than 3m long, narrower than the towing vehicle and weighs less than 200kg unladen and for private use, then you don't have to register it at all. So 90% of the 6x4 and smaller trailers are not registered.
![]() Cool, I like the sound of that... (looks carefully at section 92 of the Australian constitution.... ![]() Officer, it is a Victorian trailer, honest. ![]() ![]() ![]() I know I am in NSW but I borrowed it from a Victorian mate. ![]() |
Author: | bnicho [ Sat Aug 01, 2009 11:50 am ] |
Morris 1100 wrote: Cool, I like the sound of that... (looks carefully at section 92 of the Australian constitution....
![]() Officer, it is a Victorian trailer, honest. ![]() ![]() ![]() I know I am in NSW but I borrowed it from a Victorian mate. ![]() I looked into that one via the NSW RTA. We can tow an unregistered 6x4 trailer into SA or NSW without an issue. As soon as it is attached to a non-VIC registered car it becomes illegal. ![]() (To clarify, the 3m length is the absolute length including any load, not just the bed length.) |
