It is currently Sat Aug 02, 2025 1:32 pm
 Post subject: drilling out screws
PostPosted: Fri Jul 31, 2009 8:20 pm
hey guys and gals
i was just taking off my rear number plate flapper mijiggy
and managed to round out a screw......... (feel quite stupid now)
anyone got any hints on drilling out screws before i go dig myself a bigger hole.
Hoba
 Post subject: Re: drilling out screws
PostPosted: Fri Jul 31, 2009 8:26 pm
estapol wrote:
hey guys and gals
Hoba
Use penetrating oil before starting.
Drill it from the back so when the drill grabs the screw it will wind out.
See if you can get a pair of vice grips on the screw.
Use some heat with a heat gun if you can.
Drill with a small drill first and make sure it runs straight.
Move to the next size drill if you have got the first one to run straight,
You may be able to cut a slot in the screw with a dremmel and use a flat screwdriver (It may even work from behind)
PostPosted: Fri Jul 31, 2009 8:31 pm
use penetrating oil before starting. :wink:
PostPosted: Fri Jul 31, 2009 8:39 pm
Resident Haemorrhoid
estapol wrote:
hey guys and gals
Hoba
Morris knows all about penetrating :wink: :wink: :wink: :wink: :lol: :lol:
mtsmini wrote:
Tombo wrote:
PostPosted: Fri Jul 31, 2009 8:41 pm
Before drilling Centre Punch It
PostPosted: Fri Jul 31, 2009 9:00 pm
I guess especially with oil!!!
PostPosted: Fri Jul 31, 2009 9:03 pm
If you have a Dremel (or Bunnings spec equivalent like me) just cut a neat slot in the screw head for an F ing big flat blade screwdriver. Then just unscrew it. Use penetrating oil before starting. :)
