gear box question https://www.ausmini.com/forums/viewtopic.php?f=2&t=55658 |
Author: | i got a mini [ Sat Aug 01, 2009 3:48 pm ] |
Post subject: | gear box question |
hey well i am in need of a new gear box now i have a all syncro box which has a chance of jumping out of 2nd what i want to no is am i able just to replace the gear that was worn or do i have to replace all the gears in the box ? |
Author: | david rosenthal [ Sat Aug 01, 2009 4:30 pm ] |
with any gearbox do the lot or it gets expensive in the long run ie stuffed box and eng. if the gears are ok, then new brgs, and seals . check the syncro rings for clearance or replace. Replace the springs in the two selector hubs as well |
Author: | i got a mini [ Sat Aug 01, 2009 5:50 pm ] |
So can u just replace one syncro |
Author: | i got a mini [ Sat Aug 01, 2009 7:34 pm ] |
Author: | blue_deluxe [ Sat Aug 01, 2009 7:43 pm ] |
you could replace one gear. But then theres a very high chance youll have to rip the whole lot out again to replace the next broken bit you were to tight to fix when you had the chance. |
Author: | i got a mini [ Sat Aug 01, 2009 7:45 pm ] |
Oh ok because the syncro is the only thing worn out |
Author: | david rosenthal [ Mon Aug 03, 2009 12:16 am ] |
you will probably find that when you strip the box to do the second syncro ring , there will be plenty of other worn out things like brgs etc. It could turn into a major rebuild so be prepared for it |
