It is currently Sat Aug 16, 2025 3:43 am
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2, 3  Next
 Post subject: has me stumped.....
PostPosted: Fri Jul 31, 2009 3:22 pm
i really am sstumped i have an engine but when i try to start it it jusdt wont start it fires every now and then but wont run i have spark have fuel pumpen and have tried some aerostart stuff and i really dont know why it wont start any one have any ideas???? they will be greatly appreciated.
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Fri Jul 31, 2009 3:26 pm
check timing isn't to far retarded
PostPosted: Fri Jul 31, 2009 3:31 pm
Is the distributer set correctly and have you got the plug leads the right way around ? Remember the rotor button goes anti-clockwise and the plugs fire 1-3-4-2 , if you set it thinking it goes clockwise it will fart and cough but probably not fire .
PostPosted: Fri Jul 31, 2009 3:43 pm
Make sure a Telegraph Pole hasn't fallen onto your engine bay.
PostPosted: Fri Jul 31, 2009 3:44 pm
Tomboss Breweros
Does it seem any more or less likely to fire with aerostart?
Like the other guys suggest, i'd be looking at the ignition side :wink:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Jul 31, 2009 3:45 pm
You can get it to start with the leads "clockwise".
My son proved it :roll:
PostPosted: Fri Jul 31, 2009 3:46 pm
you sound like your having the same issue i was
http://www.ausmini.com/forums/viewtopic ... highlight=
My problem was caused by a small piece of metal fragment stuck in the carburettor which was preventing the pin from lifting. Chamber came off, bit of cleaning, back together again. Done and finished.
PostPosted: Fri Jul 31, 2009 4:12 pm
aerostart doesnt affect it at all. leads are correct points set right valves done right good spark. when you say prevented pin from lifting what do you mean?
1970 mini k
1975 leyland
PostPosted: Fri Jul 31, 2009 4:55 pm
Check the dissy isn't 180 degrees out if you've just refitted it.
Also check you actually have 12 voilts at start. If less you may still get a spark but not enough of one to fire the engine up.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Fri Jul 31, 2009 5:32 pm
If it hasnt been running for a long time sometimes they can be hard to start & when you get them going they take a few good revs to clear them out & make them idle & rev properly. A trick we used at NMP to start our imported "scrap yard" A+ engines when they were being a pain to start was to 24 volt the starter motor, they would fire up every time.
Have a Nice Day.
PostPosted: Fri Jul 31, 2009 5:35 pm
dizzy is right.its a new motor had rit running last week and now it wont start and i have no idea why.if it is blocked and not letting fuel in where would it be blocked?
1970 mini k
1975 leyland
PostPosted: Fri Jul 31, 2009 6:38 pm
Valves Riding? Check valve clearance...
Manifold vacuum leak?
Dave
PostPosted: Fri Jul 31, 2009 6:44 pm
So it was running and you have not changed a thing and it will not run. Now you have been turning it over and over and it will not start.
Check the spark plugs. Pull a plug out and sit it against the head with the lead in place and see if the plug sparks.
have reset valves
1970 mini k
1975 leyland
PostPosted: Fri Jul 31, 2009 6:46 pm
OK , back to basic's , it's a new motor and has run , have you changed anything since it last ran , how did it run last time (hot ? slow revving ? Well ? ) , how long ago did it run ? Any chance of water getting into the fuel tank since then ? Maybe take a spark plug out and see if it's wet with fuel or bone dry ?
Users browsing this forum: No registered users and 310 guests
