It is currently Mon Aug 11, 2025 2:24 am
 Post subject: Polishing my Grill
PostPosted: Mon Aug 03, 2009 3:27 pm
Looked i the how too but wanted to get a " chrome " finished on my Rover Mk6 Grill ( same as mark 3 but with internal bonnet release ) and wanted to know what products work best. Was thinking Autosol and a rotary polishing tool could work well but thought it best to ask before getting stuck in.
Thanks
Garth
Its not the size that matters.........
Rover Mini Cooper 1993 spi - current
Rover Mini Cooper 1998 ( Tahti Blue/white)
Rover Mini Cooper 1992 ( Brg),1987 Mayfair
PostPosted: Mon Aug 03, 2009 3:33 pm
They are stainless steel correct?
I find that my dremel tool and autosol works BRILLIANTLY on S/Steel
PostPosted: Mon Aug 03, 2009 3:38 pm
Rover grilles are aluminium.
PostPosted: Mon Aug 03, 2009 3:44 pm
Not all of them and i think mine may be SS ? How can i tell ?
PostPosted: Mon Aug 03, 2009 3:59 pm
Well if its steel it will be three times heavier than if its aluminium.
PostPosted: Mon Aug 03, 2009 4:02 pm
If you take a piece of steel wool to a spot on the back of the grill somewhere, give it a rub on the surface.
Ally will scratch and show where you have been rubbing,
Stainless steel will polish and generally not do anything to the metal.
And as above, ally is a lot lighter than stainless...
PostPosted: Mon Aug 03, 2009 4:19 pm
Great ! thanks will do that
PostPosted: Mon Aug 03, 2009 6:28 pm
A good way to polish chrome and Stainless is "SIFA" steel wool. super fine 0000 grade.
It works. Test on a non critical part. But It does work well.
Got mine from Bunnings 50g about $9 (i think) lasts for ages, there is heaps in 50g
Steve
"Boris" - '69 Cooper S Mk 2
PostPosted: Mon Aug 03, 2009 7:44 pm
Yep both Mick Ans 4myego have it, Use 0000 steel wool on the back of the grill and then tryout the Autosol also. inwhich you may aswell take the grill off and give it a good wash both front and back
Users browsing this forum: Bing [Bot] and 112 guests
