It is currently Fri Aug 15, 2025 6:50 am
 Post subject: Rocker Cover Gaskets
PostPosted: Sun Aug 02, 2009 1:03 pm
Apart from the cork gaskets are there still the re-usable rubber ones available?
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Sun Aug 02, 2009 1:49 pm
Not that I know.....I made one from a piece of conveyor belt I 'made use of' from work. Pretty thick stuff and it works well.
Rod Image
PostPosted: Sun Aug 02, 2009 5:36 pm
I glue the std cork one to the rocker cover and coat the bottom with a smear of grease - can re-use a few times for rocker adjustments etc.
Daniel
PostPosted: Sun Aug 02, 2009 6:15 pm
be careful with the replacement ones, i bought one and its over an inch short. a bit of heat might have been able to stretch it but i was impatient and it broke
PostPosted: Sun Aug 02, 2009 6:22 pm
As my remember it, my father in the old days when I was a just a little kid,
use to soak cork gaskets in water when they were too small, but the picture
is quite fuzzy.
PostPosted: Mon Aug 03, 2009 7:50 am
Quite correct, hot water.
Al
Users browsing this forum: No registered users and 241 guests
