Brake problems---still
https://www.ausmini.com/forums/viewtopic.php?f=2&t=55733
Author:  estapol [ Mon Aug 03, 2009 8:51 pm ]
Post subject:  Brake problems---still
Righto,
I rebuilt my brakes the other week....
Bled the absolute shite out of them with a one way hose thingy.....
adjusted them (and yes in the same way as the forward motion of the wheel.
NOW when im stationary the pedal is hard (which is good) but the faster i go the pedal gets softer... wierd or not?
any advice is good advice
Cheers Hoba
Author:  Tombo [ Mon Aug 03, 2009 10:12 pm ]
Yep, weird.
How are the wheel bearings? Movement can push the brakes back causing a bad pedal.
Author:  gafmo [ Mon Aug 03, 2009 10:36 pm ]
Yep easy check to. Jack car up and grab the tyre/wheel at 12 and 6 oclock an give it a wiggle. While your at it do left to right also. Do on all four corners as may aswell
