Preparing for the Outback
https://www.ausmini.com/forums/viewtopic.php?f=2&t=55790
Page 1 of 2
Author:  Drexxle [ Wed Aug 05, 2009 10:11 pm ]
Post subject:  Preparing for the Outback
Ok, although in Adelaide and my trip is in halt mode for a couple of weeks, i still need to get prepared for the Oodnadatta Track and Beyond.
So i put a list together of stuff i think i will need to take with me, i may be going overboard a bit, but if you can think of anything else that i have forgotten let me know
http://www.googajoob.com/v3/index.php?module=article&node=search&page=display&articleid=58
Author:  mini maxx [ Wed Aug 05, 2009 10:20 pm ]
Maybe a second car to put all the stuff in :shock:
Author:  awdmoke [ Wed Aug 05, 2009 10:27 pm ]
Maybe 2 wheel studs to go with the spare nuts, and a wheel bearing.
Also fit one of the spare fan belts in place in between the fan & engine and cable tie out of the way. Works rally cars always had a spare "ready to go" in this manner.
Author:  73GT [ Thu Aug 06, 2009 7:40 am ]
you got spare ball joints?
Author:  VicMini13 [ Thu Aug 06, 2009 7:57 am ]
I was thinking of a spare radiator if space permitted (they're not heavy) or at least getting yours pressure tested before leaving when I noticed the lack of radiator hoses in your list :oops:
Also ask if Steve will donate a box of miscellaneous nuts and bolts in mini sizes and threads. He must a couple of tonnes of them laying around with the number of old bodies he's dismantled of the years.
Author:  sports850 [ Thu Aug 06, 2009 8:16 am ]
I'm not sure where you get them from but look into hiring an EPIRB (emergency position indicating radio beacon) so if you have a serious problem (accident , fire , whatever) you can call help quickly .
Author:  poeee [ Thu Aug 06, 2009 8:35 am ]
CABLE TIES!
Author:  Mattmini [ Thu Aug 06, 2009 8:38 am ]
If its moving and it shouldnt be, duct tape.
If its stuck and it shouldn't be, CRC.
Author:  Drexxle [ Thu Aug 06, 2009 11:04 am ]
Duct Tape CHECK
CRC CHECK
Cable Ties (In Various Sizes) CHECK
Ball Joints and Caps CHECK
Wheel Bearings Pregreased ON THE LIST
Box of Bolts and Nuts CHECK
EPIRB Considered Hiring One from the Royal Flying Doctor Service
Wheel Studs ADDED TO THE LIST
SPare Radiator CONSIDERED and BEING SOURCED the last one had an egg put in it and was swapped out in Melbourne.
Still working on getting this lot together. Thanks for the replies.
Author:  frednutz&co [ Thu Aug 06, 2009 4:31 pm ]
two way radio 2meg to contact rfds :)
Author:  Wombat [ Thu Aug 06, 2009 5:33 pm ]
Oodnadatta Track was where I broke an accelerator cable (in the Land Cruiser) - Only did a short stretch - pretty sandy - got some sand mats? (I know Minis are light but you can't carry it 100 metres) And don't attempt the Stoney Dessert - you won't clear the gibber :lol:
Author:  Flute [ Thu Aug 06, 2009 7:44 pm ]
If your getting an EPIRB (and I wouldn't go without one) make sure it is a 406 with GPS positioning. Never go anywhere you shouldn't just because you have an EPIRB either, it can take a long time for rescuers to get to you. But most of all, have a great trip!
Author:  sports850 [ Thu Aug 06, 2009 7:52 pm ]
Have you got a 300 mm by 300 mm bit of 10 mm steel plate to jack the mini on in sand ? Also a couple of small tarps , one to lay on while removing things and one to work on so you don't lose springs , nuts or bearings .
Author:  lil-ute [ Fri Aug 07, 2009 12:16 am ]
what about your wallet with cash and credit card you never know someone might want money for a part you need :lol: :lol:
Author:  lushy90 [ Fri Aug 07, 2009 1:18 am ]
kitchen sink?
