door trims https://www.ausmini.com/forums/viewtopic.php?f=2&t=55869 |
Author: | AWOODY [ Sat Aug 08, 2009 7:18 pm ] |
Post subject: | door trims |
I pulled out the door trims from the woody today and the cardboard backing is not good what do you suggest as a replacement or to firm the original up . They are 850 type trims |
Author: | 74snail [ Sat Aug 08, 2009 7:24 pm ] |
Have a look at this stuff, people have used this before and it does the job, scroll down to the Laminated Sheet. http://www.corex.net.au/PRODUCTS/ExtrudedSheetProducts/Corflute-Fluteboard.aspx |
Author: | AWOODY [ Sun Aug 09, 2009 5:39 pm ] |
Thanks for that , any other suggestions? |
Author: | Mick [ Sun Aug 09, 2009 5:45 pm ] |
The original upholstery card can be purchased in sheets from upholstery suppliers such as Daleys AMU out at Parramatta. I've used it a number of times and find it nice enough to use. |
Author: | minidrifter [ Sun Aug 09, 2009 10:44 pm ] |
trimboard from daleys next to villawood, i've used 3mm mdf for my door panel. |
Author: | drmini in aust [ Mon Aug 10, 2009 9:28 am ] |
minidrifter wrote: trimboard from daleys next to villawood, i've used 3mm mdf for my door panel.
I do hope you sealed the back with fibreglass resin or something. Otherwise if/when it gets wet, it will revert to being tree-shaped. ![]() |
Author: | minidrifter [ Mon Aug 10, 2009 11:24 am ] |
sure did, hard as a rock once it cured ![]() |
