It is currently Sun Aug 17, 2025 7:11 pm
PostPosted: Fri Aug 28, 2009 3:20 pm
Hi all
The inside rear view mirror I have has broken the plastic holder (swivel bit), that goes between the mirror holder & the arm.
What holds the mirror is position?
Does the mirror come out without breaking it?
Can I get the broken plastic bit or get it made?
Its an early model mini mirror with tinted glass.
1967 Morris Mini Deluxe
1927 Austin 7
PostPosted: Sat Aug 29, 2009 3:28 pm
Has anyone taken the mirror out without breakage?
What holds the mirror in?
1927 Austin 7
PostPosted: Sat Aug 29, 2009 3:46 pm
The mirror was designed to break off in an accident, thats why it is mounted with the plastic base. they do unclip and you can re fit them, if you have broken the plastic mount then you will need to find a good S/H one as new ones are not available, except maybe NOS. Try John Smidt.
Have a Nice Day.
