It is currently Tue Jul 08, 2025 3:39 am
 Post subject: no brake lights.
PostPosted: Sat Aug 08, 2009 5:18 pm
I is a mookenik
ok this problem has been happening for the last few months been driving me insane.. thought i fixed the problem the first time.. no 2 weeks later problem again.. fixed the problem again about a week later... now a few days ago once again my brakes lights stop working.
i checked the globes and fuses still good. so im thinking wiring or switch.
the vans a 72 clubby with the switch on the line in the engine bay rather then the electric switch on the pedal. i was checking the wires over and the lights started to work... soon as i shut the bonnet they didnt work again... i disconnected the wires and checked again was getting power and if i bridged the wires the lights came on.
im wondering anyone had a wiring diagram for the vans??
PostPosted: Sat Aug 08, 2009 7:08 pm
The pressure switch has passed its use-by date. Bin it and fit a new one. (waiting for DrMini to come on and say that all new ones are crap and to fit one to the brake pedal 8) )
PostPosted: Sat Aug 08, 2009 8:21 pm
and while your at it fit a new fuse in the wiring loom behind the carby.
PostPosted: Sat Aug 08, 2009 9:22 pm
It's the twin SU's, they'll be the problem.
PostPosted: Sat Aug 08, 2009 9:26 pm
Change it to a proper clubby one :wink: ill be doing taht to my van also 8)
PostPosted: Sat Aug 08, 2009 10:13 pm
What do you mean a proper Clubby one? 8)
PostPosted: Sat Aug 08, 2009 11:18 pm
the switch on the pedal was there for a brake fail warning light, not the actual brake light switch.... right?
IE if the pedal switch is on, but the pressure switch is off, then you're gonna crash
PostPosted: Sat Aug 08, 2009 11:26 pm
Nah, the fail switch is on the master cylinder, the brake light switch is on the pedal.
But he could hardly describe it as a "proper clubby one". They were only fitted to the very last Australian cars in 77/78. Most "Clubbies" didn't have them.
Tomboss Breweros
Are the wiring terminals at the switch tight? they get worn and dirty, new ones might fix it :wink:
I've never fitted one but a relay would probably make the switch last a lot longer.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat Aug 08, 2009 11:36 pm
The first switch lasted 40 years. How long do you want it to last? :lol:
PostPosted: Sat Aug 08, 2009 11:38 pm
long enough for Tiny to get his car to a mechanic to fix it?
I had a switch stop working a year or so ago - it spun me out - I didn't think it was possible for them to stop working....
PostPosted: Sat Aug 08, 2009 11:59 pm
Tomboss Breweros
I've replaced a few in my mini time.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun Aug 09, 2009 1:26 am
I is a mookenik
problem solved.... i replaced the switch but it wasnt the problem. the power wire going to the switch must be broken inside so i just made a new wire going to the switch problem solved.
thanks guys.
PostPosted: Sun Aug 09, 2009 12:27 pm
thanks guys.
Keep the old switch Joe, you might need it again when the newie carks it. :lol:
What happens is, you have to push harder and harder to get stop lights. Worst in cold weather. :evil:
I got- 3 months out of one new hydraulic one,
3 weeks out of another,
and 12 months out of a grotty old s/h one from a wrecking yard.
Then finally I bit the bullet and fitted a late Clubby mechanical switch. These work better anyway, the brake lights come on just BEFORE you get brake pressure in the system (if you adjust it properly). So that dill sitting on your arse might not hit you.....
PostPosted: Mon Aug 10, 2009 7:09 pm
I is a mookenik
your talking about the ones on the brake pedal doc?
yeah the bloody lights dont come on till my foots pretty much slamed down on the thing.
