removal of fuel tank
https://www.ausmini.com/forums/viewtopic.php?f=2&t=5597
Author:  sean [ Wed Mar 16, 2005 10:35 pm ]
Post subject:  removal of fuel tank
I am going to remove the fuel tank soon so i can weld a new rear valance on and a patch in the boot floor. Should I take the fuel line off too up to the carby or just run the car with the tank out to ensure there is no fuel around, Anyone done this job before ? Don't want to explode !. Will be using MIG
Author:  drmini in aust [ Thu Mar 17, 2005 6:11 am ]
I'm doing the same job now- just take the tank out, what is in the line will drain back out.
Then, wrap a thick plastic bag over the end of the line with a rubber band to hold it on. :wink:
Author:  J_A_M [ Thu Mar 17, 2005 7:44 am ]
I welded a new boot floor AND rear valance into JAM. Obviously removed the tank, but I simply left the fuel line in the car....in fact, I left the hose open at the end that came off the tank.
I lived to tell the tales.... :) but you can't be too complacent.
Author:  sean [ Thu Mar 17, 2005 9:54 am ]
ok
will give it a go
ta
Author:  miniVan [ Thu Mar 17, 2005 10:36 am ]
the worst that would happen is the lil rubber bit at the end would catch on fire.. and this would only happen if you fire up the mig straight after taking the tank out.. (or try to weld ontop of it in whch rubber is quite capable of burning all by itself) leave it for half n hour till that "petrol" smell goes.. and your just staring at bit of rubber hose that might aswell be a water line
it requires massive amounts of explosives to get a car to behave like they do in the movies
Author:  fuzzy-hair-man [ Thu Mar 17, 2005 10:52 am ]
Just remember to take the battery out before you take any fuel tank out right or left hand side I reckon. It is possible to forget to do this and it is bad news if you get a spark. :shock:
Author:  sean [ Thu Mar 17, 2005 12:00 pm ]
Feel much safer now guys.
will post pics of my work if anyone is at all interested
Author:  minimark [ Thu Mar 17, 2005 2:55 pm ]
Also with welding on cars, if your welder runs on power and needs to be earthed byt the machine, remove the battery, can fry your electrics.
