extractors
https://www.ausmini.com/forums/viewtopic.php?f=2&t=55975
Author:  zachary [ Tue Aug 11, 2009 8:09 pm ]
Post subject:  extractors
Hey people out there I am just wondering how you can tell if your car has extractors?
Probably silly question but im a newbie so shoot.
Cheers Zachary
Author:  jimmyinamini [ Tue Aug 11, 2009 8:12 pm ]
u cant tell it is impossible :D
na kidding im sure some one will post some piks or someyhing
Author:  zachary [ Tue Aug 11, 2009 8:29 pm ]
Haahaha lets hope so
Author:  1018cc [ Tue Aug 11, 2009 8:32 pm ]
Extractors are pretty much anything that isn't the standard one piece cast inlet / exhaust manifold. You can tell the standard manifold because the exhaust pipe will start right up near the carbs where as with extractors the single exhaust pipe will start down behind the engine / under the car.
Author:  zachary [ Tue Aug 11, 2009 9:22 pm ]
So if the three pipes join to one pretty much straight away then I don't have em
Author:  1018cc [ Tue Aug 11, 2009 9:27 pm ]
exactly, but you can have 3 into 1 extractors which join together at the same point as well, but they join 1/2 way down the back of the engine.
Author:  zachary [ Tue Aug 11, 2009 9:43 pm ]
Alrighty will have to check next time its light and I can see everything
Author:  1310/71 [ Tue Aug 11, 2009 9:46 pm ]
If you go onto the minisport or minispares websites, they have some good pics of the Extractors they sell. As nick said, if yours look like Nick described, or like in the pictures on the site, then you will have extractors. if not, you don't (more than likely).
KB
Author:  Mick [ Tue Aug 11, 2009 9:50 pm ]
Even simpler is looking at the steel. If it is smooth and you can see welding, then it is extractors, but a stock exhaust manifold will be sand cast finished and look a little like your engine block.
Author:  zachary [ Tue Aug 11, 2009 9:59 pm ]
Great thanks for the help ill post back tomorrow my findings
Author:  minifreak1 [ Wed Aug 12, 2009 7:58 am ]
they will look like this or close too this...
these are two piece types from link Brownrigg's..but most are the same...some will be in three pieces ie....the bend at the end at the collector piece will be seperate to aid installation...
and the 3 piece type..
Author:  zachary [ Tue Aug 18, 2009 5:00 pm ]
Hi everyone well I think I do have 3 into 1 extractors well the 3 pipes join into 1 about half way down the back of the engine.
Now I am just wondering what sort would be best if I was to put a new exhuast system through it
