It is currently Wed Jul 23, 2025 6:21 pm
 Post subject: drums
PostPosted: Thu Aug 13, 2009 9:12 am
i was rebuilding my drums last night and when it came time to fit the drum over the shoes i found it was quite a tight fit, and the shoes are rubbing against the drum. how do i fix this?
is it simply worn/stretched springs?
or have i put the shoes in wrong?
thanks,
Leighton
any help is appreciated.
PostPosted: Thu Aug 13, 2009 9:26 am
ginger ninja
ginger ninja
Hi Leighton,
Have you wound the adjustment right out?
sports850 wrote:
PostPosted: Thu Aug 13, 2009 9:29 am
If Jess' solution doesn't fix (it should) check that you don't have oversize brake shoes which are designed for drums machined bigger than normal.
PostPosted: Thu Aug 13, 2009 10:16 am
yeah ive wound the adjustment out (it only spins on one offset axis doesn't it or is it; as you wind more and more it adjusts more and more?) and they're not over size shoes?
PostPosted: Thu Aug 13, 2009 10:27 am
Tomboss Breweros
Front or back?
Front with the drum off wind the adjuster either way to allow the shoe back.
Back wind the adjuster out of the backing plate.
Are the pistons seized?
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Aug 13, 2009 5:08 pm
front ones
with new wheel cylinders. ill have a close look tonight and report back if i fix it.
