BLACK SMOKE?? - Just fuel?? https://www.ausmini.com/forums/viewtopic.php?f=2&t=56002 |
Author: | Lockie91 [ Wed Aug 12, 2009 8:40 pm ] |
Post subject: | BLACK SMOKE?? - Just fuel?? |
Hi guys, one of my engines seems to blow a fair bit of black smoke. I adjusted the fuel mixture, but it still doesent seem to make much difference?? Is there any other reason aside from too much fuel (Rich) why an engine would blow black smoke?? Thanks Lockie. |
Author: | poeee [ Wed Aug 12, 2009 8:47 pm ] |
Worn jet, needle or both. Rebuild the carbie. |
Author: | 1970cooper [ Thu Aug 13, 2009 3:33 pm ] |
Had this problem on my old clubby,it could be the anti pollution canister sucking fuel from the fuel tank straight into the rocker cover.I blanked all the lines on the canister and this fixed the problem. I had to retune the engine due excess fuel before. Regards Felix |
Author: | Lockie91 [ Thu Aug 13, 2009 4:55 pm ] |
1970cooper wrote: Had this problem on my old clubby,it could be the anti pollution canister sucking fuel from the fuel tank straight into the rocker cover.I blanked all the lines on the canister and this fixed the problem. I had to retune the engine due excess fuel before.
Regards Felix sounds plausable but I don't have this on my mini, so can't be that. Must be the carby then?? |
Author: | jess [ Thu Aug 13, 2009 5:52 pm ] |
Lockie91 wrote: 1970cooper wrote: Had this problem on my old clubby,it could be the anti pollution canister sucking fuel from the fuel tank straight into the rocker cover.I blanked all the lines on the canister and this fixed the problem. I had to retune the engine due excess fuel before. Regards Felix sounds plausable but I don't have this on my mini, so can't be that. Must be the carby then?? If it is the 1978 mini, it should by law have the anti pollution gear (someone correct me if I'm wrong). I vote carbie problems |
Author: | Lockie91 [ Thu Aug 13, 2009 6:03 pm ] |
jess wrote: Lockie91 wrote: 1970cooper wrote: Had this problem on my old clubby,it could be the anti pollution canister sucking fuel from the fuel tank straight into the rocker cover.I blanked all the lines on the canister and this fixed the problem. I had to retune the engine due excess fuel before. Regards Felix sounds plausable but I don't have this on my mini, so can't be that. Must be the carby then?? If it is the 1978 mini, it should by law have the anti pollution gear (someone correct me if I'm wrong). I vote carbie problems nah its actually bluey's spare engine. not the 78 mini. The 78 mini runs like a charm, not a single bit of smoke. ![]() |
Author: | blue_deluxe [ Thu Aug 13, 2009 6:22 pm ] |
Your not having too much luck with your engines. Give us a yell if you still want that 1100 that came with the black mini. |
Author: | mini maxx [ Thu Aug 13, 2009 6:37 pm ] |
Make sure the engine isnt secretly on fire ![]() ![]() ![]() |
Author: | gerg [ Thu Aug 13, 2009 6:58 pm ] |
Maaaaate, just had this priblem with Scarlet, and it turned out to be an air leak ![]() ![]() |
Author: | Lockie91 [ Thu Aug 13, 2009 7:10 pm ] |
gerg wrote: Maaaaate, just had this priblem with Scarlet, and it turned out to be an air leak
![]() ![]() hmmm, thats certainly something im going to look for now ![]() ![]() |
