how hard is it to fit a tacho and modern speedo to a '62 850 https://www.ausmini.com/forums/viewtopic.php?f=2&t=56064 |
Author: | josh_atkins91 [ Fri Aug 14, 2009 6:38 pm ] |
Post subject: | how hard is it to fit a tacho and modern speedo to a '62 850 |
hey guys just wondering how hard it would be to fit a new speedo and tacho into my '62 850. will be fitting them so they can be removed if i sell it. also what is a good brand of guages that is resonably priced. |
Author: | Super-mini [ Fri Aug 14, 2009 6:44 pm ] |
smiths and they look period also which is the only thing i'd do with a '62 850 ![]() you could use a speedometer from an mg or austin healey |
Author: | minifreak1 [ Fri Aug 14, 2009 9:51 pm ] |
I love these... ![]() there AUTOMETER OLD TYME WHITE II 5" QUAD GAUGE & TACH/SPEEDO right up from ebay listing.. Size: KIT, 5" (127mm) Type: In-Dash Tachs & Speedos Range: 8000RPM/120 MPH/100 PSI/100-250 deg. F/8-18 Volts/240ΩE-33ΩF Notes: Operates on 4, 6, or 8 cylinder engines with points, electronic, and most 12V high performance racing ignitions. Includes all gauges senders, including 7/8-18 speedometer sender. Resettable Trip odometer. Will work with most factory sensors. If sender may be required, see model 5291 or 5292 in Accessories Section. Features Vintage-Style Domed Lens i think the look the duck nuts... price is just under $600 aus.. not bad considering you are getting spedeo....rev gauge...plus fuel water volts and oil.. |
Author: | spraycanmansam [ Fri Aug 14, 2009 11:43 pm ] |
Check these out... >>>Lotsa Gauges!<<< |
