It is currently Tue Aug 12, 2025 5:50 am
 Post subject: can u do it
PostPosted: Fri Aug 14, 2009 8:39 pm
hey guys i was wondering is it possible to fit ABS brakes to a mini or is it not worth it just curiouse thats all
PostPosted: Fri Aug 14, 2009 8:47 pm
an advance driving course would be better i reckon, teaches you manual ABS.
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Fri Aug 14, 2009 8:53 pm
I thought about fitting a kit to my mini years ago, there was a kit available for about $500 from a website that sold various electronics, cameras etc. (allthings.com.au)
I think the main problem with ABS on a mini is the weight, there's not a lot of weight on the tyres, which makes them easy to lock up. ABS releases when it senses locking, so on a light car, the stopping distance is likely to increase unless the ABS is very responsive. Which might be the reason we've only started seeing ABS on small cars in the last few years
It's just like trying to stop a car with ABS on gravel or mud - Poeee did a little test on his WRX in the mud at Hay, stopping distance was much shorter with the ABS fuse out
PostPosted: Fri Aug 14, 2009 8:55 pm
High heel ninja
Why would you ythink of this? Mini's unless disc braked don't stop, so what would ABS do?
Doogie
PostPosted: Fri Aug 14, 2009 9:03 pm
After teaching unacoutable ladies how to drive a manual including my own wife in a moke :lol: that was fun....the best advvise I would give is get yourself & or partners to partisipate in Khrana or Motokharana's and where you can skid pan, it will teach you how to use your brakes when, where and how needed. I did a lot of "park" work when I was younger both front and rear wheel drive and its been got me out of alot of possible disasrters
PostPosted: Fri Aug 14, 2009 9:15 pm
i was just wondering if u could do it thats all
PostPosted: Fri Aug 14, 2009 9:18 pm
wouldnt be worth the hassle i reckon mate, they weight of the car and the suspension bounce etc would make it go off when its not needed probably too
Potato
It could be done. :D
I have it in my MINI.
PostPosted: Fri Aug 14, 2009 9:23 pm
wouldn't it need a computer of sorts
PostPosted: Fri Aug 14, 2009 9:31 pm
Retrofit a modern car one - it should be able to be done if you can put in engines etc
PostPosted: Fri Aug 14, 2009 9:47 pm
all good if you want to fit the ecu out of that car too..
Potato
PostPosted: Fri Aug 14, 2009 9:55 pm
I should've posted this:
YOU CAN DO IT!
PostPosted: Fri Aug 14, 2009 9:59 pm
haha nice pic lol i was just wondering cause in the near future i wanna do up my brakes and just trying to find out what to go with thinking just cooper s disk atm
PostPosted: Fri Aug 14, 2009 10:07 pm
If youve got 12 inch wheels+ then go for 8.4" vented 4 pot discs off a metro turbo. Cheap as when imported from england and always good fun proving people wrong when they say you cant get vented 4 pots for minis.
Simplify and add lightness
PostPosted: Fri Aug 14, 2009 11:49 pm
who says that? there are at least 4 different varieties :?
Users browsing this forum: No registered users and 111 guests
