It is currently Fri Aug 22, 2025 8:17 am
PostPosted: Mon Aug 17, 2009 1:23 pm
Can anyone tell me how the hydrolastic pipes are positioned on english built minis? I am putting hydrolastic suspension back in my mini but it has been fitted with reproduction floors which don't have the indentation for the hydrolastic lines to fit into. Has anyone else had this problem? if so what did you do?
Lindsay Palmer
06 Mazda SP23
80 Alfa GTV (weekend toy)
86 626 Turbo (daily drive, now stolen)
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Mon Aug 17, 2009 1:42 pm
My 850 is dry but I'm pretty sure that it used to be hydro. I'll check it out and try and take some photos this evening to show where the channels run.
PostPosted: Mon Aug 17, 2009 5:35 pm
Oz Deluxe and Cooper S up to 1967 (no hydro channels) had the pipes straight along under the floor, clipped on, with a little tin protector guard at each end.
Sorry I don't have a pic...
PostPosted: Mon Aug 17, 2009 9:10 pm
From memory they run alongside the tunnel - much like the brake lines/battery cable.
Cheers, Ian
PostPosted: Mon Aug 17, 2009 10:18 pm
Dr Mini did the pipes still run along the centre of the floor or against the tunnel?
Thanks for the information everyone.
Lindsay Palmer
06 Mazda SP23
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Tue Aug 18, 2009 6:18 am
Hi Lindsay,
I can take photos if you are stuck. The hydro pipes run beside the battery cable, brake and fuel lines.
Regards
Al
PostPosted: Tue Aug 18, 2009 7:08 am
On Oz cars the early hydro pipes were not in the tunnel. Neither were the fuel and brake lines. Dunno about UK cars.
PostPosted: Tue Aug 18, 2009 7:34 am
I'm the opposite to you Doc, know the UK cars but not much about Orstralian cars (other than Holdens!)
Al
PostPosted: Tue Aug 18, 2009 8:03 am
The hydro pipes run the same as the brake line and battery cable on the drivers side, and its mirror image for the passenger.
I remember someone a while back fabricated the recesses for the hydro pipes themselves, and then welded in captive nuts to support the hydro covers.
Users browsing this forum: Bing [Bot] and 124 guests
