It is currently Sat Aug 23, 2025 11:07 pm
 Post subject: K.A.D Quick shift????
PostPosted: Tue Aug 18, 2009 12:13 pm
hey guys just wanted to know your thoughts on the K.A.D quickshift?
Is it worth putting in? does it make that much of a difference from the standard?
The BLUE BRIK ;-)
PostPosted: Tue Aug 18, 2009 12:24 pm
Plenty of discussion here. I like them but a lot don't for various reasons
http://www.ausmini.com/forums/viewtopic.php?t=51810&highlight=quickshift
PostPosted: Tue Aug 18, 2009 12:43 pm
very helpfull link... are most mini gearboxes sloppy?
i was thinking of getting the quick shift to help reduce the slopyness...
The BLUE BRIK ;-)
PostPosted: Tue Aug 18, 2009 1:40 pm
Fix the sloppiness... then you wont have the need for the quick shift..
probably cheaper too..
PostPosted: Tue Aug 18, 2009 1:49 pm
Almost any gearbox will be sloppy after 30-50 years.
I have a remote box & have been through and replaced the worn parts already, but have just bought a KAD Quickshift.
Hopefully will get a chance to fit it this weekend. Will let you know how it goes...
PostPosted: Tue Aug 18, 2009 2:17 pm
had one in a remote box, hated it
PostPosted: Tue Aug 18, 2009 2:46 pm
got one in mine to reduce sloppiness but not much longer new box and motor going in :)
PostPosted: Tue Aug 18, 2009 3:09 pm
This space for rent
I have a MiniSpares quickshift (same as the KAD except it doesn't have the collar lift to engage reverse; you lift the whole stick as usual) on a rodchange box and it's great. There's not much slop in my rodchange to begin with (I appear to have the only tight rodchange gearshift in the country going by the comments hereabouts) and the quick shift works really well.
The only criticism I have is that first is a little hard to engage some times (4 synchro box) but aside from that I love it 8)
PostPosted: Tue Aug 18, 2009 5:46 pm
I bought a KAD quickshift for my new white cars and the instructions want me to put the mechanism inside the car :?: 8)
PostPosted: Tue Aug 18, 2009 7:05 pm
I have one, and dont mind it.
PostPosted: Tue Aug 18, 2009 7:21 pm
i have one too..kad one .....i love it but some dont like them..once you get used to it its great....
mines quite old....9 years idd say...the new type have lift up for reverse as mentioned...
i diddnt like the long stick so i cut it down....felt better...
PostPosted: Tue Aug 18, 2009 8:26 pm
Ribena's got a KAD one fitted - it's brilliant. Absolutely no slop in the gear changes - very direct - love it.
Hooroo
Rod Image
