electric fuel pump and gauges. https://www.ausmini.com/forums/viewtopic.php?f=2&t=56181 |
Author: | Leighton [ Tue Aug 18, 2009 5:52 pm ] |
Post subject: | electric fuel pump and gauges. |
ive bought an electric fuel pump but i have no idea how to put it in and get it working. where should it be located? do i need any extra fittings like fuel hoses/pipes? i also need to Know about my eletric gauges. ive bought 3 smiths gauges (oil p., Volts, water temp) where can i get the fittings and wiring for these, i have also heard you can get a t-piece connection for the oil p and have a light in there too, where can i get all these bits and how do i wire them up? thankyou, Leighton |
Author: | i got a mini [ Tue Aug 18, 2009 5:56 pm ] |
depends what type of car u got but electric check under the back subframe in the corner near the back left wheel |
Author: | Leighton [ Tue Aug 18, 2009 5:58 pm ] |
sorry i havent put it in yet, is it meant to go under the fuel tank? |
Author: | i got a mini [ Tue Aug 18, 2009 6:30 pm ] |
yer on the outside of car jack the back up stick ya head under there and up in the cornere will be ya old one if u have electric |
Author: | i got a mini [ Tue Aug 18, 2009 6:33 pm ] |
![]() thats were it should be lol mine dont have a electric but that is were it is ment to go |
Author: | tinymorris1969 [ Tue Aug 18, 2009 6:36 pm ] |
ill post a pic for u when i get home mate. its not hard to do, took me about 15 mins to connect and wire up. |
Author: | minifreak1 [ Tue Aug 18, 2009 7:17 pm ] |
this is how i did mine....was told to use one rubber mount but i did two. ![]() shes not wired up yet as i have no loom....but its one wire to earth and other to main power on ignition ie...turn key and she gets power.....well i think thats right ?? |
Author: | drmini in aust [ Tue Aug 18, 2009 9:12 pm ] |
They are quieter if mounted on a Mini front exhaust pipe mounting. The 2 bolt holes line up perfect... ![]() |
Author: | Leighton [ Tue Aug 18, 2009 9:24 pm ] |
ok thanks for the replies. do i need any extra fuel hose/pipe lengths? |
Author: | drmini in aust [ Tue Aug 18, 2009 9:33 pm ] |
Yes. 1 metre is plenty, get decent hoseclamps that fit properly (no stiff wormdrive ones). I use USA made fuel hose, it doesn't go hard when using unleaded fuel. |
Author: | Leighton [ Tue Aug 18, 2009 9:42 pm ] |
thankyou for your help in both threads ![]() |
