It is currently Sat Jul 19, 2025 6:16 am
 Post subject: Mini engine questions
PostPosted: Fri Mar 18, 2005 11:46 am
My mini doesnt seem to go anywhere when you put your foot down ( 1100cc, leyland mini ), she revs up to bout 5000-6000rpm ( is this normal or can they go higher? ) but really has no power, im told the carb is a bit buggered and needs a new needle and seat, seems to blow a bit of black smoke and is running real rich, any similar probs anyone has had, could it be something else? any info would be appreciated....
Just remember, wherever you go..........................there you are
PostPosted: Fri Mar 18, 2005 11:48 am
If it's running rich, it's usually a worn needle. Get the carb prob fixed and see what it's like after that.
PostPosted: Fri Mar 18, 2005 11:51 am
Will a needle and seat come in a rebuild kit? Just got quoted $43.50 for a kit from repco,
PostPosted: Fri Mar 18, 2005 11:52 am
Possibly not? Don't quote me on that, though.
PostPosted: Fri Mar 18, 2005 11:59 am
no they dont. because there are so many needles about ( marked in no particualr order :S
lookin for another clubby
PostPosted: Fri Mar 18, 2005 12:00 pm
so would i need to pull mine out and get another one matched? where would i go for this?
PostPosted: Fri Mar 18, 2005 12:01 pm
SU Midel has the goods. 8)
http://www.sumidel.com/
PostPosted: Fri Mar 18, 2005 12:29 pm
It would help if we knew what size your carb was in the first place, if a 1.25" S, you really aren't gonna be going anywhere even if you rebuild it ;)
With a 1.25" SU your going to struggle to see north of 5000rpm anyway..
Ideally you don't want to see much more than 6-6.5k...
You want at least a 1.5" on something that is close to stock..bigger if mildly worked..
PostPosted: Fri Mar 18, 2005 12:36 pm
poeee wrote:
If it's running rich, it's usually a worn needle. Ge t the carb prob fixed and see what it's like after that.
I'd dispute that. If it has the correct needle in it there is a simple way to see if it is running rich at idle. warm it up and undo the damper screw. Gently lift the piston using the damper a couple of mm. If it speeds up it is rich and if it slows down it is lean. Little or no change is ideal. The needle will only get worn if the jet is not centred. If this was the case then the piston will stick. If the jet erodes (and they do) it will start to run rich, then replace the jet. The jet, if replaced has to be centred so the damper doesn't stick. Leave the jet loose and after lifting the damper push it down quickly and then do uo the jet. Check and repeat if necessary.
Chris
Everything I like is either
PostPosted: Fri Mar 18, 2005 12:44 pm
YES this kit includes the float chamber needle and seat. NOT the carb mixture needle. :lol:
PostPosted: Fri Mar 18, 2005 12:46 pm
Its a 1.5 hs4
PostPosted: Fri Mar 18, 2005 12:55 pm
Are you comparing the performance to some level you've had before? It probably isn't going to be that quick anyway..
What are the engine specs?
extractors?
Head?
Cam?
etc...
Where are you located?
PostPosted: Fri Mar 18, 2005 12:58 pm
im not comparing it to anything, this is my first mini, its standard apart from a scorcher rebuilt dissy, full exhaust and the sidedraught su,
PostPosted: Fri Mar 18, 2005 1:02 pm
Do some head work, a nice cam and you should notice a big difference..
Stock 1100 isn't going to be that fast, mine has had alot of work and puts out about twice the HP as a stock 1100 and i still wouldn't call it fast ;) but it sure is fun :)
Don't know what a scorcher dissy is though..?
PostPosted: Fri Mar 18, 2005 1:25 pm
Scorcher is the name of the company, and i just mean that they rebuilt it, they are more commonly known for doing 6's and 8's
